20.01.2019, 08:33 | #1 |
cleverax: The use of “Planning item” production type for grading process in manufacturing
Источник: https://cleverax.wordpress.com/2019/...manufacturing/
============== There is a Production type field on the released product form that drives product behavior in production, for example, if you set it to None you may notice that you cannot create neither Formula nor Bill of materials version for it (the buttons are simply grayed out) which also means that you won’t be able … Continue reading The use of “Planning item” production type for grading process in manufacturing → Источник: https://cleverax.wordpress.com/2019/...manufacturing/ |
