Старый 19.01.2024, 14:41   #5
Lankey is offline
Lankey
Сообщение от Товарищ ♂uatr Посмотреть сообщение
Hey. We are using server's command: System.Net.ServicePointManager::set_SecurityProtocol(System.Net.SecurityProtocolType::SystemDefault); // exactly "default", this value recommended by MS
and yeah AOS' .net framework version to use 1.2/1.3 should be increased via the configuration change.
https://learn.microsoft.com/en-us/do...ntext-switches
Sorry, I'm a bit confused:
1) When you are talking about the configuration change , do you mean that you use the same config file that was given in the S.Kuskov's post above?
2) Where do you use System.Net.ServicePointManager::set_SecurityProtocol(System.Net.SecurityProtocolType::SystemDefault); ?
dynamics ax 2009
ax2009: сервер постоянно что-то делает. почему? mazzy DAX: Администрирование 28 01.06.2016 16:58
axinthefield: Choosing a Single Deployment or Multiple Deployments of AX2009 Blog bot DAX Blogs 0 15.06.2011 03:25
sumitax: SharePoint 2010 and AX2009 Blog bot DAX Blogs 0 11.11.2010 11:11
Shekhar: Dynamics AX2009 : Standalone Installation on Vista with Role centres and workflow. Blog bot DAX Blogs 0 30.03.2010 15:05
ax2009 & SSRS kitty DAX: Программирование 6 02.04.2009 10:38
Часовой пояс GMT +3, время: 07:36.
