Интересно, что пока решал проблему, нагуглил вот такое описание
https://blogs.msdn.microsoft.com/flo...x-and-the-clr/
The garbage collector in Dynamics Ax is very simple: it collects all unreferenced object every 3 seconds (ok, this is a little bit simplified, but it’s pretty much what the GC does). Consequently you know when the object is collected: about every 3 seconds and if this doesn’t happen you can use the Form SysHeapCheck to create a dump of the current heap, so you know how many references are currently held to that object. Another point that differentiates X++ with C# is the existing of a destructor. In X++ this destructor is called "finalize()". As described on Msdn: X++ objects are destructed automatically when there are no more references to them. You can destruct them explicitly in the following ways: - Use the finalize method. - Set the object handle to null. In X++ it's the finalize method that contains all code that is used to clean up the instance (releases all objects that are held by this instance, ...). In C# this is done by the Dispose() method, but I'll describe this later. An important point is mentioned in the Msdn documentation ( http://msdn.microsoft.com/en-us/libr...74(AX.10).aspx https://web.archive.org/web/20130517...8AX.10%29.aspx https://docs.microsoft.com/en-us/dyn...ectedfrom=MSDN ): Use finalize carefully. It will destruct an object even if there are references to it. Вероятнее всего это какой-то глюк в ядре аксапты, воспроизводимость которого зависит от ряда (неизвестных) случайных факторов. Видимо поэтому он и не исправлен до сих пор. |
Теги |
7zip, finalize, garbage collector, gc, rar, textio, winrar, архивирование |
