palleagermark: Improve searches in docs
Источник: https://www.agermark.com/2021/08/imp...s-in-docs.html
============== The search experience at docs.microsoft.com is not great. It is more like broken. Here is how you can improve search with your favorite search engine. I'm using Edge/Bing for the example, but this can easily be changed to Chrome/Google.
In the browsers address bar type your keyword, i.e. D365FO. It will notw ask you if it should use the search you just defined: Click the button, and the search bar changes into this: Type your query: And behold: To do the same search, just manually, you can enter the following: Now I challenge you try to find the same article with the built in search on docs, without typing the precise title of the article. If you can manage that, you are smarter than me (which doesn't say lot however). Источник: https://www.agermark.com/2021/08/imp...s-in-docs.html
