Старый 13.03.2021, 00:13   #1
ax.docentric: Comment on Improved Email Templates – Creating Email Body with Dynamic Table by Ana Gligorijevic
Источник: https://ax.docentric.com/improved-em.../#comment-2123
In reply to VardhaRaj.Hi,Before creating and sending an email message, you can check if there is no data (lines) used for populating the dynamic table in the email template, so in that case you can use a different email template without the dynamic table.Alternatively, you can create a pre-event handler for the DocEmailTemplateManager::generateEmailBodyAndSubjectWithDynamicLines() method and pre-process the email body with placeholders as a string containing HTML to remove the empty HTML table. This code could look like this:const str repeatingBlockMarkStart = &apos;<!&dash;&dash;%HIDDEN_TABLEBEGIN%&dash;&dash;>&apos;;const str repeatingBlockMarkEnd = &apos;<!&dash;&dash;%HIDDEN_TABLEEND%&dash;&dash;>&apos;;
int posBegin = strScan(_emailBodyWithPlaceholders, repeatingBlockMarkStart, 1,
    strLen(_emailBodyWithPlaceholders));int posEnd = strScan(_emailBodyWithPlaceholders, repeatingBlockMarkEnd, 1,
    strLen(_emailBodyWithPlaceholders)) + strLen(repeatingBlockMarkEnd);
if ((posEnd - posBegin) > strLen(repeatingBlockMarkStart) + strLen(repeatingBlockMarkEnd)){  emailBody_FirstPart = subStr(_emailBodyWithPlaceholders, 1, posBegin - 1);  emailBody_LastPart = subStr(_emailBodyWithPlaceholders, posEnd,
        strLen(_emailBodyWithPlaceholders));  newEmailBody = emailBody_FirstPart + &apos;<BR>&apos; + emailBody_LastPart;}
Hope that this helps.Kind regards,Ana
Старый 13.03.2021, 00:13   #2
ax.docentric: Comment on Improved Email Templates – Creating Email Body with Dynamic Table by VardhaRaj
Источник: https://ax.docentric.com/improved-em.../#comment-2121
Hi Team,How can I hide the dynamic table when there is no data in it?Example:The dynamic table has 0 rows, but it still shows the header and values as zero. I need to hide the table when there is no data.
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 6 Blog bot DAX Blogs 0 01.09.2014 14:11
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Часовой пояс GMT +3, время: 23:17.
