For each 2-tier session Axapta starts at least three (3) connections against
the database: • Session used primarily for sequence-number generation and other system management tasks. This connection is referred to as the system connection. Reason for this session is to avoid update of “SystemSequences” to be part of a current active transaction, which would make it sequence-number generation a bottleneck in the system. • Application connection, which generally is used for running the business logic of the application. • Read-only connection, which is similar to the application connection, but no data manipulation operations are executed on this type of connections. Clients browsing data in Forms will typically use a read-only connection. • Optional user connections. The X++ language provides a number of ways to have “user defined” connections, which is accomplished by instantiating classes of type Connection, UserConnection, or OdbcConnection (refer to the “Axapta Developer’s Guide” for details). (c) Databases advanced |
Тема | Ответов | |||
daxis: Troubleshooting orphaned sessions and SPIDS in Dynamics Ax | 0 | |||
Dynamics AX: Convergence Sessions Round-up | 0 | |||
Fred Shen: Limited sessions in Axapta | 0 | |||
Sessions (Ещё) | 9 |
Опции просмотра | |
