Старый 11.11.2019, 23:05   #1
alicedr is offline
alicedr
насколько я вижу, заполняется поле тут (в дебаггере вижу что таки заполняется):
class MCRPaymentReview
public static boolean outOfBalance(MCRCustPaymTotals _mcrCustPaymTotals,
                             AmountCur _overUnderPaymAmount = 0,
                             AmountCur _totalSalesAmount = 0)
else
            // Update back status gets called from so many places that a new
            //                      enum value was added so that only end order can put a
            //                      sales order on out of balance "hold".
            //                   So once end order validates that this is not out of balance
            //                      make sure that it doesn't happen again unless the order
            //                      is modified.
            mcrSalesTable.OutOfBalanceReleased = MCROutOfBalanceReleaseType::Verified;
        ttsBegin;
        if (salesTable.validateWrite())
            salesTable.mcrPackMCRSalesTable(mcrSalesTable);   //<<----------------------------
            salesTable.update();
        else
            throw error("@SYS104318");
        ttsCommit;
        return isValid;
public class SalesTable extends common
    /// <summary>
    /// Packs the retail sales table extension table into <c>MCRSalesTable</c> field.
    /// </summary>
    /// <param name="_mcrSalesTable">
    /// Extension table to be packed.
    /// </param>
    public void mcrPackMCRSalesTable(MCRSalesTable _mcrSalesTable)
        _mcrSalesTable.SalesTable = this.RecId;
        this.SysExtensionSerializerMap::packExtensionTable(_mcrSalesTable);
mcrsalestable, packedextensions, sysextensionserializermap
sertandev: How to receive D365FO push notifications using Azure Notification Hubs Blog bot DAX Blogs 0 04.07.2019 18:11
sertandev: How to integrate D365FO with Microsoft Flow using the new Business Events Blog bot DAX Blogs 0 23.05.2019 16:11
d365technext: Pass field value from SalesTable to CustTrans in AX 2012 & D365FO Blog bot DAX Blogs 0 15.11.2018 09:11
erconsult: Copy-paste with keyboard script 2: from Excel to D365FO Blog bot DAX Blogs 0 03.08.2018 11:12
littleax: Part1. Dynamics ax 2012. Split construct method by models. Blog bot DAX Blogs 0 28.05.2014 10:11
Часовой пояс GMT +3, время: 21:39.
