Старый 13.01.2019, 06:02   #1
yetanotherdynamicsaxblog: Important changes to how we will update the production going forward
Источник: http://yetanotherdynamicsaxblog.blog...ll-update.html
Not long ago, it was published on docs some updates on how we will be doing self-servicing of our non-production environments. There is one particular statement I want to address with this post:
You will need to provide a combined deployable package for customizations. That is, all custom extension packages, including ISV packages, must be deployed as a single software deployable package. You will not be able to deploy one module at a time. This was always a recommended best practice and is now enforced.
It has been recommended for a long while to always ensure any changes to the application, either updates or when adding new modules, these are services to the sandbox and then to production in one single package. And then I mean the same single package containing everything which is not already in standard. This would include:
  • ISV solutions and deliveries
  • Customer specific customizations (ie from your partner)
  • Hotfixes (relevant only for version 8.0 and older supporting individual hotfixes)
It may seem counter-intuitive and unnecessary to do it like this. You may argue we should be able to push individual modules and updates to the sandbox and to production. Why enforce "single package"? What are the benefits of this?
The core reason is that we are moving away from actually updating the application, but we are instead actually replacing the application. The application becomes an immutable piece of software, that does not change or is susceptible to change.
This means the "updated" version of the application instead is setup and runs on a new instance, replacing the previous version of the application. The new pattern will sustain and ensure the following expectations:
Predictability - One single package having all the code and metadata, and all the module dependencies secured, ensures the same behavior every time it is used in a deployment.
Repeatability - Repeating the same package deployment on the next environment should have little to no risk, for example when repeating the install done in sandbox when installing in production.
Recovery & Rollback - The single package is a good known state which can let us rollback to, in case we need to recover due to deployment failure.
Scale-out - Reusing the same single package lets us easily and safely repeat deployment on new instances, and allowing for a safe and easy way to scale out.
Portability - The same package can be safely used if you for whatever reason needs to relocate your installation somewhere else around the world.
Think about all the benefits of this. It is music in my ears.
In theory, today, you could service your sandbox and production with individual packages. You could yourself handle the order you install the packages, to ensure not breaking dependencies. You could use a test environment to try test updated versions of packages, in order to see if they broke something in conjunction with any of the other existing packages. It is possible - but it is not recommended.
Reading the announcement of the new immutable pattern for self-servicing environments is great news. It may change the way you've published updates in the past, if you used to push individual "delta" packages. If you've published single packages from your build environment, you're following best practices, and the enforcement will not change how you've done things.
What do you think about this? Share your comments and thoughts either in the comments or on Twitter.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 14 Blog bot Dynamics CRM: Blogs 0 12.07.2013 07:13
Часовой пояс GMT +3, время: 20:54.
