Старый 02.11.2018, 14:11   #1
d365technext: Default parameters can be wrapped In extension classes COC
Источник: http://d365technext.blogspot.com/201...rapped-in.html
In Build-8.1 you can override the default parameter by using class extension COC.
Code reference
There is the method in HCMWORKER table isEmployee in which you can see the default value set with _validFrom & _validto.
publicHcmIsEmployee isEmployee(
utcdatetime _validFrom = DateTimeUtil::utcNow(),
utcdatetime _validTo = _validFrom
HcmIsEmployee hcmIsEmployee = NoYes::No;
HcmEmployment hcmEmployment;
unchecked(Uncheck::XDS)
if (prmisDefault(_validFrom) && prmisDefault(_validTo))
selectfirstonly RecId from hcmEmployment
where hcmEmployment.Worker == this.RecId
&& hcmEmployment.EmploymentType == HcmEmploymentType::Employee;
elseif (_validFrom == _validTo)
selectfirstonly ValidTimeState(_validFrom) RecId from hcmEmployment
else
selectfirstonly ValidTimeState(_validFrom, _validTo) RecId from hcmEmployment
if (hcmEmployment.RecId != 0)
hcmIsEmployee = NoYes::Yes;
return hcmIsEmployee;
So we created extension class of Hcmworker with name of Demo_Extension and override the method using COC.
[ExtensionOf(tableStr(HcmWorker))]
finalclassDemo_Extension
utcdatetime _validFrom,
next isEmployee(_validFrom,_validTo);
selectfirstonlyValidTimeState(_validFrom) RecId from hcmEmployment
else
selectfirstonlyValidTimeState(_validFrom, _validTo) RecId from hcmEmployment
Now perform build & Sync on your module..
d365technext: Product Receipt validation in Extension using COC D365FO Blog bot DAX Blogs 0 11.09.2018 00:14
d365technext: Label Extension D365FO Blog bot DAX Blogs 0 07.08.2018 19:11
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Передача функции в качестве параметра lemchey_white DAX: Программирование 20 21.01.2008 22:51
Часовой пояс GMT +3, время: 21:42.
