Старый 04.10.2018, 18:11   #1
a33ik: Change Tracking Usage
Источник: http://daxonline.org/1625-change-tracking-usage.html
Runnable class to install/re-install/disable change tracking scopes
VKChangeTrackingSetupMode enum:
class VKChangeTrackingSetup extends RunBase{ VKChangeTrackingSetupMode setupMode; DialogField setupModeFld; #define.CurrentVersion(1) #localMacro.CurrentList setupMode #endmacro}public void run(){ new AifChangeTrackingPermission().assert(); info(strFmt("Change tracking setup mode '%1'", enum2str(setupMode))); this.setupDbChangeTracking(); // Add here the methods to enable change tracking for your queries this.setupMagentoProducts(); this.setupMDAProducts(); // Make sure that the batch job which updates change trackng version is scheduled ttsBegin; AifChangeTrackingVersionUpdateJob::createBatchJob(); ttsCommit; CodeAccessPermission::revertAssert();}protected Object dialog(){ DialogRunbase dialog; DialogGroup dialogGroup; dialog = super(); dialog.caption("Setup change tracking scopes"); dialogGroup = dialog.addGroup(); DialogGroup.columns(2); dialogGroup.frameType(FormFrameType::Thin); dialog.addImage(931); dialog.addText("The option 'Install all scopes' will disable existing scopes before re-installing them. This will discard any previously tracked versions.", 500); dialogGroup = dialog.addGroup(); setupModeFld = dialog.addFieldValue(enumStr(VKChangeTrackingSetupMode), setupMode); return dialog;}protected void disableQueryChangeTracking(AifChangeTrackingScope _scope){ AifChangeTrackingConfiguration::disableChangeTracking(_scope); AifChangeTrackingConfiguration::deleteTouchTriggers(_scope);}protected void enableQueryChangeTracking( Query _query, AifChangeTrackingScope _scope, boolean _createInsertTriggers = true, boolean _createUpdateTriggers = true, boolean _createDeleteTriggers = true){ AifChangeTrackingConfiguration::enableChangeTrackingForQuery( _scope, _query, AifChangeTrackingType::SqlChangeTracking, _createDeleteTriggers); if (_createInsertTriggers) AifChangeTrackingConfiguration::createTouchTriggersForQuery(_scope, AifChangeTrackingTriggerType::AfterInsert, _query); if (_createUpdateTriggers) AifChangeTrackingConfiguration::createTouchTriggersForQuery(_scope, AifChangeTrackingTriggerType::AfterUpdate, _query);}public boolean getFromDialog(){ boolean ret; ret = super(); setupMode = setupModeFld.value(); return ret;}public container pack(){ return [#CurrentVersion, #CurrentList];}protected void scheduleCtVersionUpdates(){ if (setupMode != VKChangeTrackingSetupMode::Disable) AifChangeTrackingVersionUpdateJob::createBatchJob();}protected void setupDbChangeTracking(){ if (setupMode != VKChangeTrackingSetupMode::Disable && !AifChangeTrackingConfiguration::isChangeTrackingEnabled()) { AifChangeTrackingConfiguration::enableChangeTracking(true); } info(AifChangeTrackingConfiguration::isChangeTrackingEnabled() ? "Database change tracking is enabled" : "Database change tracking is disabled");}private void setupMagentoProducts(){ this.setupQueryChangeTracking(queryStr(MagentoProductChangeTracking), 'MagentoProducts');}protected void setupMDAProducts(){ this.setupQueryChangeTracking(queryStr(MDAProductInfoChangeTracking), 'MDAProducts');}protected void setupQueryChangeTracking( str _queryName, AifChangeTrackingScope _scope, boolean _createInsertTriggers = true, boolean _createUpdateTriggers = true, boolean _createDeleteTriggers = true){ Query query; AifChangeTracking changeTracking; boolean isEnabled; setPrefix(strFmt("Change tracking scope '%1'", _scope)); query = new Query(_queryName); changeTracking = AifChangeTracking::construct(query, _scope, AifChangeTrackingType::SqlChangeTracking); isEnabled = changeTracking.isChangeTrackingEnabledForQuery(); switch (setupMode) { case VKChangeTrackingSetupMode::InstallNew: if (!isEnabled) this.enableQueryChangeTracking(query, _scope, _createInsertTriggers, _createUpdateTriggers, _createDeleteTriggers); break; case VKChangeTrackingSetupMode::InstallAll: if (isEnabled) this.disableQueryChangeTracking(_scope); this.enableQueryChangeTracking(query, _scope, _createInsertTriggers, _createUpdateTriggers, _createDeleteTriggers); break; case VKChangeTrackingSetupMode::Disable: if (isEnabled) this.disableQueryChangeTracking(_scope); } info(changeTracking.isChangeTrackingEnabledForQuery()? "Change tracking for query is enabled" : "Change tracking for query is disabled");}public boolean unpack(container packedClass){ Version version = RunBase::getVersion(packedClass); switch (version) { case #CurrentVersion: [version, #CurrentList] = packedClass; break; default: return false; } return true;}public static VKChangeTrackingSetup construct(){ return new VKChangeTrackingSetup();}public static void Main(Args _args){ VKChangeTrackingSetup::MainOnServer(_args);}private server static void MainOnServer(Args _arhs){ VKChangeTrackingSetup changeTrackingSetup; changeTrackingSetup = VKChangeTrackingSetup::construct(); if (changeTrackingSetup.prompt()) { changeTrackingSetup.run(); }}
MagentoProductChangeTracking, MDAProductInfoChangeTracking - queries in AOT with exact fields list. Changes in the stated datasources and its field list will be tracked.
Helper class to get changed entities:
class VKChangeTrackingHelper{ AifChangeTracking changeTracking; AifChangeTrackingScope scope; UnknownNoYes fullSyncRequired;}public AifChangeTrackingTable getChanges(){ AifChangeTrackingTable changeTrackingTable; utcDateTime lastSyncDate; lastSyncDate = VKChangeTrackingScope::getLastSyncDate(scope); changeTracking.getChanges(lastSyncDate, changeTrackingTable); return changeTrackingTable;}public boolean isFullSyncRequired(){ utcDateTime lastSyncDate; if (fullSyncRequired == UnknownNoYes::Unknown) { lastSyncDate = VKChangeTrackingScope::getLastSyncDate(scope); if (changeTracking.isFullSynchronizationRequired(lastSyncDate)) fullSyncRequired = UnknownNoYes::Yes; else fullSyncRequired = UnknownNoYes::No; } return fullSyncRequired == UnknownNoYes::Yes;}public void new(Query _query, AifChangeTrackingScope _scope){ scope = _scope; changeTracking = AifChangeTracking::construct(_query);}
Table to save last sync date:
Fields:
  • LastSyncDate, EDT: DateTimeExecuted
  • Scope, EDT: AifChangeTrackingScope, unique
public static boolean exist(AifChangeTrackingScope _scope){ return _scope && ( select RecId from VKChangeTrackingScope where VKChangeTrackingScope.Scope == _scope).RecId != 0;}public static VKChangeTrackingScope find(AifChangeTrackingScope _scope, boolean _forUpdate = false){ VKChangeTrackingScope changeTrackingScope; changeTrackingScope.selectForUpdate(_forUpdate); if (_scope) { select firstOnly changeTrackingScope where changeTrackingScope.Scope == _scope; } return changeTrackingScope;}public static utcDateTime getLastSyncDate(AifChangeTrackingScope _scope){ VKChangeTrackingScope changeTrackingScope; changeTrackingScope = VKChangeTrackingScope::find(_scope); return changeTrackingScope.LastSyncDate;}public static void updateLastSyncDate( AifChangeTrackingScope _scope, utcDateTime _dateTime = DateTimeUtil::getSystemDateTime()){ VKChangeTrackingScope changeTrackingScope; ttsBegin; changeTrackingScope = VKChangeTrackingScope::find(_scope, true); if (!changeTrackingScope) { changeTrackingScope.Scope = _scope; } changeTrackingScope.LastSyncDate = _dateTime; changeTrackingScope.write(); ttsCommit;}
Usage
Modify initial query to add Aif change tracking table:
if ( exportMode == VKInterfaceExportMode::Delta && !changeTrackingHelper.isFullSyncRequired()) { qbds = qbds.addDataSource(tableNum(AifChangeTrackingTable)); // should be joined to primary datasource of change tracking query. In this case we are tracking changes on the InventTable qbds.addRange(fieldNum(AifChangeTrackingTable, RecId)) .value(strFmt('(%1.RecId == %2.KeyField_RecId)', qbdsInventTable.name(), qbds.name())); }AifChangeTrackingTable is temporary table and is filled in by helper class. The instance of this temp table should be added to QueryRun:
queryRun = new QueryRun(query); if ( exportMode == VKInterfaceExportMode::Delta && !changeTrackingHelper.isFullSyncRequired()) { queryRun.setRecord(changeTrackingHelper.getChanges()); } while (queryRun.next()) { //.... }
За это сообщение автора поблагодарили: ax_mct (0).
littleax: Change Tracking Blog bot DAX: База знаний и проекты 42 11.06.2019 09:40
sertandev: D365 FO: How to track data changes with AIF change tracking Blog bot DAX Blogs 0 21.07.2018 12:11
crmtipoftheday: Tip #1026: Change your perspective on tracking email Blog bot Dynamics CRM: Blogs 0 20.11.2017 09:11
stoneridgesoftware: Changes to Microsoft Dynamics NAV Change Log System: How to Revert its Behavior Blog bot NAV: Blogs 0 23.06.2016 20:13
Часовой пояс GMT +3, время: 06:12.
