alirazazaidi: Data Manipulation in Dynamics Ax 2012- Array as Extended Data Type
Источник: https://www.tech.alirazazaidi.com/da...ded-data-type/
============== I found a array based field in TSTimesheetLineWeek table, Field TSWeeklyHours Now challenge is to enabled field based on Array. For example need to disabled on day 6. ![]() Following code snippet help me to enabled disabled fields generated on the base of array extended Type TSTimesheetLineWeek_ds.object(fieldId2Ext(fieldNum(TSTimesheetLineWeek, Hours), 6)).allowEdit(false);Reference : https://msdn.microsoft.com/en-us/library/aa675074.aspx https://docs.microsoft.com/en-us/pre...92700(v=ax.50) Источник: https://www.tech.alirazazaidi.com/da...ded-data-type/
