Старый 28.06.2018, 09:37   #1
Logger is offline
Logger
3,987 / 3273 (117) ++++++++++
Записей в блоге: 2
Аналогично
=== Setup logging started: 26.06.2018 19:44:47 ===
Running file: "C:\Users\XXXX\AppData\Local\Temp\AxSetupSP\AxSetupUI.exe" RelatedFilesDir="C:\Users\XXXX\Downloads"
AXSetup version number: 6.3.4000.3530
Microsoft Windows NT 6.2.9200.0 (64 bit)
SERVER-YYYY
DOMEN\XXXX
Interactive: True
RelatedFilesDir=C:\Users\XXXX\Downloads
Property RelatedFilesDir set to: 'C:\Users\XXXX\Downloads\'
Property SetupLanguage set to: 'EN'
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2018-06-26 19-44-47\DynamicsSetupLog.txt
=== Checking parameters ===
Property InstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\60'
Property InstallPath32Bit set to: 'C:\Program Files (x86)\Microsoft Dynamics AX\60'
=== Starting UI phase ===
The underlying connection was closed: An unexpected error occurred on a send.
axupdate.exe, tls12
AX 2012 R3 CU11 upgrade to CU13 January 2018 Release problem oip DAX: Администрирование 3 22.02.2018 20:19
dynamicscpm: Management Reporter CU13 Hotfix Now Available Blog bot DAX Blogs 0 25.08.2015 11:11
Обновления печатных форм книги покупок/продаж ax2012R3 kornix DAX: Администрирование 2 03.06.2015 14:34
Сергей Герасимов: Обновления для Microsoft Dynamics AX 3.0 Blog bot DAX Blogs 0 06.02.2007 15:50
Часовой пояс GMT +3, время: 07:39.
