axtoday: Management Reporter scripts
Источник: http://axtoday.blogspot.com/2017/11/...r-scripts.html
============== Few scripts that can be used to check the MR integration tasks: Check all integration tasks that have been executed: --List details about each DDM task: state, progress, last... --List details about each DDM task: state, progress, last/next runtime in local time, and the interval that each runs --Status 5=Success; 3=Running; 6=Cancelled select CIG.[Description] , STK.[Name] , STS.[Progress] , CASE STS.[StateType] WHEN 3 THEN 'Processing' WHEN 5 THEN 'Complete' WHEN 7 THEN 'Error' END AS StateType , DATEADD(minute, DATEDIFF(minute,GETUTCDATE(),GETDATE()), STS.[LastRunTime]) as LocalLastRunTime , DATEADD(minute, DATEDIFF(minute,GETUTCDATE(),GETDATE()), STS.[NextRunTime]) as LocalNextRunTime , CM.[ContinueOnRecordError] , STRG.[Interval] , CASE STRG.[UnitOfMeasure] WHEN 2 THEN 'Minutes' ELSE 'Seconds' END AS IntervalTiming , CASE STRG.[IsEnabled] WHEN 1 THEN 'Enabled' ELSE 'Disabled' END AS NameStatus from [Connector].[Map] CM with (nolock) inner join [Scheduling].[Task] STK with (nolock) on STK.[Id] = CM.[MapId] inner join [Scheduling].[TaskState] STS with (nolock) on STK.[Id] = STS.[TaskId] inner join [Connector].[IntegrationGroup] CIG with (nolock) on CIG.[IntegrationId] = STK.[CategoryId] inner join [Scheduling].[Trigger] STRG with (nolock) on STK.[TriggerId] = STRG.[Id] order by CIG.[Description], STK.[Name] Check the tasks outcomes select CIG.[Description], ST.[Name], SM.[Text], DATEADD(minute, DATEDIFF(minute,GETUTCDATE(),GETDATE()), SL.[StartTime]) as LocalStartTime, DATEADD(minute, DATEDIFF(minute,GETUTCDATE(),GETDATE()), SL.[EndTime]) as LocalEndTime, SL.[TotalRetryNumber], SL.[IsFailed], STT.[Name] as TaskType from [Scheduling].[Log] SL with (nolock) inner join [Scheduling].[Task] ST with (nolock) on SL.TaskId = ST.Id inner join [Scheduling].[Message] SM with (nolock) on SL.Id = SM.LogId inner join [Scheduling].[TaskType] STT with (nolock) on ST.TypeId = STT.Id inner join [Connector].[IntegrationGroup] CIG with (nolock) on CIG.[IntegrationId] = ST.[CategoryId] order by SL.[StartTime] desc Check the current integration activities SELECT sqltext.TEXT, req.session_id, req.status, req.command, req.cpu_time, req.total_elapsed_time FROM sys.dm_exec_requests req CROSS APPLY sys.dm_exec_sql_text(sql_handle) AS sqltext Источник: http://axtoday.blogspot.com/2017/11/...r-scripts.html
| Теги |
| management reporter |
| Опции просмотра | |
