thwidmer: Comparison: “Use futures date as requirement date”
Источник: https://thwidmer.wordpress.com/2016/...uirement-date/
============== Setup Master plan setup – Use futures date as requirement date pl-PO Use Futures date as Requirement date = Yes pl-PO Use Futures date as Requirement date = No pl-PO + pl-Prod Use Futures date as Requirement date = No![]() Coverage group – Action Basis Date Action Basis date = Requirement date Action Basis date = Futures date![]() Test cases Scenario Sales order with confirmed delivery date: 16.11.2016; the lead time setup of the purchase item (M0009) doesn’t allow the PO to be on time. ![]() pl-PO Use Futures date as Requirement date = Yes; Action Basis date = Requirement date ![]() pl-PO Use Futures date as Requirement date = Yes; Action Basis date = Futures date ![]() pl-PO Use Futures date as Requirement date = No; Action Basis date = Requirement/Futures date Note: Changing Action Basis date does not have an affect ![]() pl-PO + pl-Prod Use Futures date as Requirement date = No; Action Basis date = Futures/Requirement date Note: Changing Action Basis date does not have an affect ![]() Recommendation USE: Use Futures date as Requirement date = Yes; Action Basis date = Requirement date With this setting the system tells you what is late and what you should try to do about it. Источник: https://thwidmer.wordpress.com/2016/...uirement-date/
