Старый 14.09.2017, 13:11   #1
sinedax: Microsoft Dynamics 365 for Finance and Operations, Enterprise edition (on-premises) - Installation PART 2
Источник: http://sinedax.blogspot.com/2017/07/...ce-and_26.html
Hi
Again here with the second part about the D365FO On-premise installation.
Before to Create the AppFabric Cluster, modify the ClusterConfig.json file created before and set the "diagnostics file share" path. This one will be use during the Installation process through all AppFabric nodes.
If during the Cluster installation you raised the error "Request is Invalid" check if the Primary NodeType (Orchestrator) have at least 3 Nodes!
Again, if during the Cluster installation you raised the error "Timed out waiting for Installer Service to complete for machine..."
You have to:
1- Verify if the Certificate are been installed in the Local Machine Node
2- Add the NETWORK SERVICE account for all certs used by Service Fabric.
In order to do this you have first download and install in all Cluster Nodes the WinHttpCertCfg.exe tool, Windows HTTP Services Certificate Configuration Tool (WinHttpCertCfg.exe)
Lastly, run the command for all Certificates in all Cluster Nodes, like "C:\Program Files (x86)\Windows Resource Kits\Tools\WinHttpCertCfg.exe" -g -c LOCAL_MACHINE\MY -s "client.xxxxx.com" -a "NetworkService"
Till soon!
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 15 Blog bot Dynamics CRM: Blogs 1 10.02.2016 10:26
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
Часовой пояс GMT +3, время: 19:18.
