Старый 03.05.2017, 16:49   #1
Ace of Database is offline
Ace of Database
Аватар для Ace of Database
877 / 649 (23) +++++++
На память оставлю, чтобы потом залезть и посмотреть
static void Job388(Args _args)
    str s = " 5  555, 55 ";
    real r;
    r = str2Num(strreplace(strkeep(s, "01234567890,.E+-"), ",", "."));
    info(strfmt("%1", r));
emeadaxsupport: Capturing an AX User’s SQL SPID over multiple AOS servers in AX 2009 Blog bot DAX Blogs 0 16.05.2013 19:11
emeadaxsupport: AX for Retail 2012: Customizing the Transaction Service Blog bot DAX Blogs 0 19.04.2012 01:14
sumitsaxfactor: Getting Ledger transactions in Ax 2012 Blog bot DAX Blogs 0 13.12.2011 22:11
sumitsaxfactor: Browsing Folders for Files on 64-bit Server Side Implementation (Batch Run) Blog bot DAX Blogs 0 26.08.2011 01:13
emeadaxsupport: How can the Web Proxies get extended programmatically? Blog bot DAX Blogs 0 16.12.2009 18:05
Часовой пояс GMT +3, время: 15:32.
