Старый 20.12.2016, 17:45   #1
Logger is offline
Logger
3,987 / 3273 (117) ++++++++++
Записей в блоге: 2
Вот набросал джобик для проверки
static void Job3798_3(Args _args)
    VirtualDataAreaList     virtualDataAreaList;
    Dataarea                Dataarea;
    int                     tick1;
    int                     tick2;
    int                     i;
    DictTable               dictTable;
    common                  common;
    common                  common2;
    container               contable =
//        [tableNum(LEDGERJOURNALPOSTCONTROLUSERGROUP), "100"] // time 0,19     steps 20000  table   LedgerJournalPostControlUserGroup (company = 100)
//        [tableNum(LEDGERJOURNALPOSTCONTROLUSERGROUP), "dat"] // time 0,17     steps 20000  table   LedgerJournalPostControlUserGroup (company = dat)
//        [tableNum(LEDGERBALANCESHEETDIMFILEFORMAT), "100"] // time 0,17     steps 20000  table   LedgerBalanceSheetDimFileFormat (company = 100)
//        [tableNum(LEDGERBALANCESHEETDIMFILEFORMAT), "dat"] // time 0,19     steps 20000  table   LedgerBalanceSheetDimFileFormat (company = dat)
//        [tableNum(SalesTable), "100"] // time 0,25     steps 20000  table   SalesTable (company = 100)
//        [tableNum(SalesTable), "dat"] // time 0,25     steps 20000  table   SalesTable (company = dat)
//        [tableNum(DIRPARTYADDRESSRELATIONSHIPMAPPING), "100"] // time 10,25     steps 20000  table   DirPartyAddressRelationshipMapping (company = gab)  win2003    - CPU 2,6 GHz
        // time 18,55     steps 20000  table   DirPartyAddressRelationshipMapping (company = gab)  win2008 R2 - CPU 2,3 GHz
//        [tableNum(DIRPARTYADDRESSRELATIONSHIPMAPPING), "dat"]   // time 10,19     steps 20000  table   DirPartyAddressRelationshipMapping (company = gab)
        // time 19,73     steps 20000  table   DirPartyAddressRelationshipMapping (company = gab)  win2008 R2
//        [tableNum(CustTable), "100"] // time 10,08     steps 20000  table   CustTable (company = hld) - win2003
                                     // time 0,22     steps 20000  table   CustTable (company = dat) - win2008 R2
//        [tableNum(CustTable), "dat"] // time 0,22     steps 20000  table   CustTable (company = dat)
//        [tableNum(SysUserLog), "100"] // time 0,20     steps 20000  table   SysUserLog (company = No savePerCompany) - win2008 R2
//        [tableNum(SysUserLog), "dat"] // time 0,19     steps 20000  table   SysUserLog (company = No savePerCompany)  - win2008 R2
        [tableNum(GRD_SpecialDeptsInventLocations), "100"] // time 14,02     steps 20000  table   GRD_SpecialDeptsInventLocations (company = msc) for win2003
                                                           // time 27,16     steps 20000  table   GRD_SpecialDeptsInventLocations (company = msc) for win2008 R2
//        [tableNum(GRD_SpecialDeptsInventLocations), "dat"] // time 0,16     steps 20000  table   GRD_SpecialDeptsInventLocations (company = dat)  for win2003
                                                           // time 0,19     steps 20000  table   GRD_SpecialDeptsInventLocations (company = dat)  for win2008 R2
    appl.setDefaultCompany(conPeek(contable, 2));
    dictTable = new SysDictTable(conPeek(contable, 1));
    common = dictTable.makeRecord();
    common.(fieldNum(common, recid)) = 123; // force kernel to create a buffer instance
    select count(recId) from Dataarea where Dataarea.isVirtual;
    info(strFMT("count VirtCompanies = %1", Dataarea.RecId));
    select count(recId) from Dataarea where !Dataarea.isVirtual;
    info(strFMT("count Companies = %1", Dataarea.RecId));
    if (!dictTable.dataPrCompany())
        info("Not percompany table");
    else
    if (xDataarea::find(common.dataAreaId).isVirtual)
        select count(recid) from virtualDataAreaList where virtualDataAreaList.virtualDataArea == common.dataAreaId;
        info(strFMT("table %1  contains  %2  companies for virtual %3", dictTable.name(), virtualDataAreaList.RecId, common.dataAreaId));
    else
        info(strFMT("table %1 is not virtual for company %2", dictTable.name(), common.dataAreaId));
    tick1 = WinApi::getTickCount();
    i = 0;
    for (i = 1; i < 20000; i++)
        common2 = common.data(); // make a buffer copy
        // also runs slowly with :
        // common2 = conpeek(con, 1);
        // common2 = map.lookup(1);
        // every time you create an instance of buffer
    tick2 = WinApi::getTickCount();
    info(strFMT(
        "time %1     steps %2  table   %3 (company = %4)",
        (tick2-tick1)/1000,
        i,
        dictTable.name(),
        dictTable.dataPrCompany() ? common.dataAreaId : "No savePerCompany"
trace parser, trace parser bug, virtual company, баг, виртуальные компании, производительность, трассировка
Тормозит разноска Заказа на Покупку с ОС vazerdim DAX: Функционал 6 24.10.2012 22:04
SQL Server 2005, 2008: Создание недостающих индексов Poleax DAX: Прочие вопросы 6 05.06.2010 01:28
CRM создание писем и их рассылка - в чем трабл? ShadowFromXZone DAX: Функционал 9 17.06.2008 16:51
Создание буфера обмена на бездисковых станциях Владимир Максимов DAX: Программирование 9 03.04.2008 11:41
Импорт из буфера vey DAX: Программирование 13 27.06.2006 16:46
Часовой пояс GMT +3, время: 20:21.
