Старый 27.07.2004, 10:14   #13
посмотрите хелп разработчика по функции match
попробуйте использовать эту функцию
Character Description
A backslash causes a specific character to be matched. For example, "\$" matches a dollar sign.
< or ^
A 'less than' (<) sign or a circumflex (^) at the start of an expression is used to match the start of a line.
> or & A 'greater than' (>) sign or an ampersand (&) at the end of the expression is used to match the end of a line.
? or . A question mark (?) or a full stop (.) will match any character (except Enter, new line).
:x A colon specifies a group of characters to be matched, indicated by the character which follows immediately after.
:a sets the match to letters
:d sets the match to numeric characters
:n sets the match to alphanumeric characters
:SPACE sets the match to blanks, tabulations, and control characters such as Enter (new line).
* An expression followed by an asterisk requires a match for none or several occurrences of the expression.
For example, "fo*" will locate "f", "fo", "foo" etc.
An expression followed by a plus (+) sign requires a match for one or several occurrences of the expression.
For example, "fo+" matches "fo" etc.
An expression followed by a minus (-) sign requires a match for no or one occurrence of the expression.
For example, "fo-" matches "f" and "fo".
A string of characters enclosed within square brackets specifies that a match is required for every character in this text, and only for these characters.
For example, "[xyz]" matches "xx" and "zyx" etc.
A string of characters can be specified by two characters separated by '-' (minus).
For example, "[a-z]" matches all letters, whereas "[z-a]" never matches.
If the first character in a text within square brackets is a circumflex (^) then the expression matches all characters except Enter (new line) and the characters in the string.
For example, "[^xyz]" matches "abc" but not "axb".
Банковский перевод. Простой вопрос LEM DAX: Функционал 0 27.03.2008 14:41
сумма по строке закупки Nikolaich DAX: Программирование 2 03.04.2007 13:37
Скидка по строке и многострочная скидка efim DAX: Функционал 0 18.06.2003 16:32
Функция "Удалить строки" Oks DAX: Функционал 1 03.07.2002 18:09
Функция RunBuf Maxim Gorbunov DAX: База знаний и проекты 0 27.11.2001 17:15
Часовой пояс GMT +3, время: 16:11.
