Старый 06.10.2016, 08:20   #1
Vadik is offline
Vadik
Модератор
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Прямо какое-то время удивительных историй. Профайлинг и сайзинг никто не делал, просто выбрали наугад тип VM и запустились. Потом что-то где-то затормозило, чувак зашел по RDP на продуктив семерки в Azure (представляю как этому удивились парни из DSE), запустил там Iometer и в очередной раз спас вселенную
-ТСЯ или -ТЬСЯ ?
Старый 06.10.2016, 10:30   #2
Morpheus is offline
Morpheus
Аватар для Morpheus
602 / 167 (7) ++++++
Case: A new AX7 implementation reported general slowness all around, not just in one form but multiple forms. Also, the slowness wasn’t limited to a particular area like financials or supply chain. It was everywhere. The company was small, less than 100 employees. The database also contained a small amount of data.
WHAT COULD IT BE: The Company is small so that rules out high volume issues unless they have a huge amount of integrations They are also a new company so that rules out an overly large database, and it usually eliminates a good percentage of detectable code performance issues (that comes when an implementation gets further along).
ANSWER: Hardware.
instructorbrandon: Case of the Slow Customer and Sales Order Forms in Dynamics AX plus Functional Hack Blog bot DAX Blogs 0 04.05.2016 06:17
emeadaxsupport: AX Performance - What information and data to collect when you want to open a support case Blog bot DAX Blogs 0 29.09.2015 15:11
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 03:51.
