Старый 17.09.2016, 07:30   #1
organicax: Item coverage setup wizard
Источник: https://organicax.com/2016/09/16/ite...-setup-wizard/
If you are setting up item coverage and you need to do it for multiple sites and warehouse then creating the entries manually could be time consuming. Luckily there is a wizard that might be useful to leverage that would save a bit of data entry time.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Supply chain planning
organicax: Item coverage copy setup Blog bot DAX Blogs 0 17.09.2016 01:16
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 12:09.
