Старый 04.08.2016, 12:11   #1
emeadaxsupport: Forms authentication provider stops working after applying May CU for SharePoint 2013
Источник: https://blogs.msdn.microsoft.com/axs...arepoint-2013/
After we installed May CU for SharePoint 2013 (15.0.4823.1003) we were not able to log with Forms authentication users and the error (404) In SharePoint log we could see the error: Exception trying get context compatibility level: System.IO.FileNotFoundException: The site https://dax2012r3.contoso.com:8090/_...uth/Login.aspx could not be found in the Web application SPWebApplication Name=DynamicsFormsSTS – dax2012r3.contoso.com-8090. at Microsoft.SharePoint.SPSite.LookupSiteInfo(SPFarm... Read more
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
emeadaxsupport: AX for Retail 2012 R2: Working with Custom Fields for Receipts Blog bot DAX Blogs 0 16.02.2013 23:12
emeadaxsupport: Microsoft Dynamics AX 2012 Form based Authentication provider has wrong connection string when the aspnetdb is created on a separate server. Blog bot DAX Blogs 0 12.09.2012 19:11
emeadaxsupport: How to change authentication of an existing Microsoft Dynamics AX 4.0 Enterprise Portal (EP) site to use IIS Basic Authentication Blog bot DAX Blogs 0 29.03.2010 21:05
Часовой пояс GMT +3, время: 20:29.
