Британский учённый
Вот еще по теме: Preserve data when AIF service call fails
Dynamics AX AIF is great for all kind of interfaces and integration with 3rd party applications. By default AIF has an built-in transaction mechanism that prevents your system to become inconsistent if something goes wrong during processing. Here is an example of a simple method which writes message data and the current transaction level into a table X++: [SysEntryPointAttribute] public void call(Description _message) { ERPServiceTable serviceTable; serviceTable.Message = _message; serviceTable.Info = strFmt("%1", appl.ttsLevel()); serviceTable.insert(); } PHP код:
AIF service call But what happens when something goes wrong during processing the service call (e.g. posting a journal fails). Here is as simple method which can be used to simulate such a situation: X++: [SysEntryPointAttribute] public void callWithError(Description _message,boolean _error) { this.call(_message); if(_error) { throw error("Exception!"); } } X++: context.MessageId = Guid.NewGuid().ToString(); client.callWithError(context, "Service Call without error", false); X++: try { context.MessageId = Guid.NewGuid().ToString(); client.callWithError(context, "Service Call 2 with error", true); } catch { Console.WriteLine("The service failed as expected!"); } Service call with error not saved However, if you want to keep the initial data for a post mortem analysis, this behavior is a problem. One way to work around this rollback is to reduce the transaction level back to 0 by calling an additional ttscommit. This will ensure no rollback will delete the transmitted data. Finally, raise the ttslevel back to 1 for further processing. X++: [SysEntryPointAttribute] public void callWithError(Description _message,boolean _error = false) { this.call(_message); ttsCommit; ttsBegin; if(_error) { throw error("Exception!"); } } Service call with error preserverd BTW. A more relaxed way to address this issue is to separate interfaces from business logic. For example provide two methods, one to transmit the data and another to process the data after it was successfully transmitted. If a second method is not an option (for what reason ever) write a batch class which processes the data. However, if you require immediate processing and a second call is not feasible this workaround may help.
Людям физического труда для восстановления своих сил нужен 7-8 часовой ночной сон. Людям умственного труда нужно спать часов 9-10. Ну а программистов будить нельзя вообще. |
За это сообщение автора поблагодарили: Logger (1). |
Теги |
aif, ax2012, user connection |
