Старый 20.11.2013, 17:44   #1
524td is offline
524td
все не могу сделать тотал для каждой строки/столбца...
вот код, еще раз..(
Код:
xlWorkSheet.Cells.Item(1,2,'Àíàëèç çàðïëàòû ïî èçìåðåíèÿì');
xlWorkSheet.Cells.Item(2,2,'Ïåðèîä ñ '+FORMAT(periodstart)+' ïî '+FORMAT(periodend));
xlWorkSheet.Range(ColInInteger(2)+FORMAT(1)+':'+ColInInteger(2)+FORMAT(1)).Font.Bold:=TRUE;
xlWorkSheet.Range(ColInInteger(2)+FORMAT(2)+':'+ColInInteger(2)+FORMAT(2)).EntireColumn.AutoFit;
xlWorkSheet.Cells.Item(toprow,2,'Íàçâàíèå');
xlWorkSheet.Range(ColInInteger(2)+FORMAT(toprow)+':'+ColInInteger(2)+FORMAT(toprow)).Font.Bold:=TRUE;
xlWorkSheet.Range(ColInInteger(2)+FORMAT(toprow)+':'+ColInInteger(2)+FORMAT(toprow)).HorizontalAlignment:=-4108;
xlWorkSheet.Range(ColInInteger(2)+FORMAT(toprow)+':'+ColInInteger(2)+FORMAT(toprow)).VerticalAlignment:=-4108;
xlWorkSheet.Range(ColInInteger(2)+FORMAT(toprow)+':'+ColInInteger(2)+FORMAT(toprow+2))._BorderAround(1,2);
xlWorkSheet.Range(ColInInteger(2)+FORMAT(toprow)+':'+ColInInteger(2)+FORMAT(toprow+2)).Merge;
TempColumnDimOption.RESET;
TempLineDimOption.RESET;
TempColumnDimOption.DELETEALL;
TempLineDimOption.DELETEALL;
pav.RESET;
pav.SETRANGE(Code,salary);
pav.FINDFIRST;
totaltotal:=0;
TotalSum:=0;
CASE LineDimOption OF
 LineDimOption::Element:
 BEGIN
   PayrollElement.RESET;
   IF element<>'' THEN
     PayrollElement.SETFILTER(Code,element);
   IF PayrollElement.FINDSET THEN
   REPEAT
   TempLineDimOption.INIT;
   TempLineDimOption.Code:=PayrollElement.Code;
   TempLineDimOption.Name:=PayrollElement.Code;
   TempLineDimOption.INSERT;
  UNTIL PayrollElement.NEXT=0;
 END;
 LineDimOption::"Element Group":
 BEGIN
   PayrollElementGroup.RESET;
   IF elementgroup<>'' THEN
     PayrollElementGroup.SETFILTER(Code,elementgroup);
   IF PayrollElementGroup.FINDSET THEN
   REPEAT
   TempLineDimOption.Code:=PayrollElementGroup.Code;
   TempLineDimOption.Name:=PayrollElementGroup.Code;
  UNTIL PayrollElementGroup.NEXT=0;
 END;
 LineDimOption::Employee:
 BEGIN
   Employee.RESET;
   IF emp<>'' THEN
     Employee.SETFILTER("No.",emp);
   IF Employee.FINDSET THEN
   REPEAT
   TempLineDimOption.Code:=Employee."No.";
   TempLineDimOption.Name:=Employee."Full Name";
  UNTIL Employee.NEXT=0;
 END;
 LineDimOption::"Org. Unit":
 BEGIN
   OrganizationUnit.RESET;
   IF organizatunit<>'' THEN
     OrganizationUnit.SETFILTER(Code,organizatunit);
   IF OrganizationUnit.FINDSET THEN
   REPEAT
   TempLineDimOption.Code:=OrganizationUnit.Code;
   TempLineDimOption.Name:=OrganizationUnit.Code;
  UNTIL OrganizationUnit.NEXT=0;
 END;
 LineDimOption::Period:
 BEGIN
  CurDate:=periodstart;
  ii:=1;
  CASE PeriodType OF
   PeriodType::Day:
     Formula:='<1D>';
   PeriodType::Week:
     Formula:='<1W>';
   PeriodType::Month:
     Formula:='<1M>';
   PeriodType::Quarter:
     Formula:='<1Q>';
   PeriodType::Year:
     Formula:='<1Y>';
  END;
  REPEAT
    CASE PeriodType OF
     PeriodType::Day:
       LastDate:=CurDate;
     PeriodType::Week:
       LastDate:=CALCDATE('<1W-1D>',CurDate);
     PeriodType::Month:
       LastDate:=CALCDATE('<1M-1D>',CurDate);
       LastDate:=CALCDATE('<1Q-1D>',CurDate);
     PeriodType::Year:
       LastDate:=CALCDATE('<1Y-1D>',CurDate);
    END;
   TempLineDimOption.Code:=FORMAT(ii);
   TempLineDimOption.Name:=FORMAT(CurDate);
   TempLineDimOption."Period Start":=CurDate;
   TempLineDimOption."Period End":=LastDate;
    ii:=ii+1;
    CurDate:=CALCDATE(Formula,CurDate);
  UNTIL CurDate>periodend;
 END;
END;
CASE ColumnDimOption OF
 ColumnDimOption::Element:
 BEGIN
   IF element<>'' THEN
   REPEAT
   TempColumnDimOption.INIT;
   TempColumnDimOption.Code:=PayrollElement.Code;
   TempColumnDimOption.Name:=PayrollElement.Code;
   TempColumnDimOption.INSERT;
 END;
 ColumnDimOption::"Element Group":
 BEGIN
   REPEAT
   TempColumnDimOption.Code:=PayrollElementGroup.Code;
   TempColumnDimOption.Name:=PayrollElementGroup.Code;
 END;
 ColumnDimOption::Employee:
 BEGIN
   Employee.RESET;
   IF emp<>'' THEN
   REPEAT
   TempColumnDimOption.Code:=Employee."No.";
   TempColumnDimOption.Name:=Employee."Full Name";
 END;
 ColumnDimOption::"Org. Unit":
 BEGIN
   REPEAT
   TempColumnDimOption.Code:=OrganizationUnit.Code;
   TempColumnDimOption.Name:=OrganizationUnit.Code;
 END;
 ColumnDimOption::Period:
 BEGIN
  ii:=1;
  CASE PeriodType OF
   PeriodType::Day:
     Formula:='<1D>';
   PeriodType::Week:
     Formula:='<1W>';
   PeriodType::Month:
     Formula:='<1M>';
     Formula:='<1Q>';
   PeriodType::Year:
     Formula:='<1Y>';
  END;
  REPEAT
    CASE PeriodType OF
     PeriodType::Day:
       LastDate:=CurDate;
     PeriodType::Week:
     PeriodType::Month:
     PeriodType::Year:
    END;
   TempColumnDimOption.Code:=FORMAT(ii);
   TempColumnDimOption.Name:=FORMAT(CurDate);
   TempColumnDimOption."Period Start":=CurDate;
   TempColumnDimOption."Period End":=LastDate;
    ii:=ii+1;
 END;
END;
Col:=3;
cnt:=TempColumnDimOption.COUNT;
IF TempColumnDimOption.FINDSET THEN
REPEAT
  xlWorkSheet.Cells.Item(toprow,Col,FORMAT(TempColumnDimOption.Name));
  xlWorkSheet.Range(ColInInteger(Col)+FORMAT(toprow)+':'+ColInInteger(Col)+FORMAT(toprow)).Font.Bold:=TRUE;
  xlWorkSheet.Range(ColInInteger(Col)+FORMAT(toprow)+':'+ColInInteger(Col)+FORMAT(toprow)).HorizontalAlignment:=-4108;
  xlWorkSheet.Range(ColInInteger(Col)+FORMAT(toprow)+':'+ColInInteger(Col)+FORMAT(toprow)).VerticalAlignment:=-4108;
  xlWorkSheet.Range(ColInInteger(Col)+FORMAT(toprow)+':'+ColInInteger(Col)+FORMAT(toprow+2))._BorderAround(1,2);
  xlWorkSheet.Range(ColInInteger(Col)+FORMAT(toprow)+':'+ColInInteger(Col)+FORMAT(toprow+2)).Merge;
  xlWorkSheet.Range(ColInInteger(Col)+FORMAT(toprow)+':'+ColInInteger(Col)+FORMAT(toprow)).EntireColumn.AutoFit;
  Col:=Col+1;
UNTIL TempColumnDimOption.NEXT=0;
w:=0;
Window.OPEN('Ïîñòðîåíèå îò÷åòà @1@@@@@@@@@@@@@@@@@@@@@');
i:=7;
cnt:=TempLineDimOption.COUNT;
IF TempLineDimOption.FINDSET THEN
  REPEAT
  w+=1;
  Window.UPDATE(1,ROUND(w/cnt*10000,1));
  element1:='';
  emp1:='';
  organizatunit1:='';
  elementgroup1:='';
      element1:=TempLineDimOption.Code;
      elementgroup1:=TempLineDimOption.Code;
      emp1:=TempLineDimOption.Code;
      organizatunit1:=TempLineDimOption.Code;
  END;
  Date1:=periodstart;
  Date2:=periodend;
  IF LineDimOption=LineDimOption::Period THEN
  BEGIN
    Date1:=TempLineDimOption."Period Start";
    Date2:=TempLineDimOption."Period End";
  END;
  TotalSum:=0;
  IF HideNull THEN
  BEGIN
    REPEAT
       IF ColumnDimOption=ColumnDimOption::Period THEN
       BEGIN
         Date1:=TempColumnDimOption."Period Start";
         Date2:=TempColumnDimOption."Period End";
       END;
           element1:=TempColumnDimOption.Code;
           elementgroup1:=TempColumnDimOption.Code;
           emp1:=TempColumnDimOption.Code;
           organizatunit1:=TempColumnDimOption.Code;
       END;
       SumAmount1:=CalcPayroll1(COMPANYNAME,Date1,Date2,element1,emp1,organizatunit1,elementgroup1);
       TotalSum+=SumAmount1;
       totaltotal+=SumAmount1;
  END;
  IF ((TotalSum<>0) AND HideNull) OR (NOT HideNull) THEN
  BEGIN
    xlWorkSheet.Cells.Item(i,2,FORMAT(TempLineDimOption.Name));
    xlWorkSheet.Range(ColInInteger(2)+FORMAT(i)+':'+ColInInteger(2)+FORMAT(i))._BorderAround(1,2);
    xlWorkSheet.Range(ColInInteger(2)+FORMAT(i)+':'+ColInInteger(2)+FORMAT(i)).EntireColumn.AutoFit;
    Col:=3;
    REPEAT
        BEGIN
        END;
        END;
        IF SumAmount1<>0 THEN
            xlWorkSheet.Cells.Item(i,Col,FORMAT(SumAmount1));
        xlWorkSheet.Range(ColInInteger(Col)+FORMAT(i)+':'+ColInInteger(Col)+FORMAT(i))._BorderAround(1,2);
        xlWorkSheet.Range(ColInInteger(Col)+FORMAT(i)+':'+ColInInteger(Col)+FORMAT(i)).EntireColumn.AutoFit;
        Col:=Col+1;
    i:=i+1;
  END;
UNTIL TempLineDimOption.NEXT=0;
xlWorkSheet.Cells.Item(i,Col-1,FORMAT(totaltotal));
xlWorkSheet.Range(ColInInteger(Col-1)+FORMAT(i)+':'+ColInInteger(Col-1)+FORMAT(i)).EntireColumn.AutoFit;
Window.CLOSE;
Часовой пояс GMT +3, время: 18:45.
