Старый 27.10.2009, 14:50   #11
Storkich is offline
Storkich
Вот .vbs файл, можно генерить из нава и отправлять
Код:
Set objEmail = WScript.CreateObject("CDO.Message")  'Create CDO-object and get link on it into objEmail (var)
' Required parameters of CDO-object
objEmail.From = "robot@Sercer.ru"                         'Sender (mine) address
objEmail.To = "DPugaev@Server.ru"                                     'Address of recipient or distribution list
'objEmail.BCC = "DPugaev@Server.ru"                             'Hide copy recipient address
objEmail.Subject = "Field Management Report "      'Subject of message
objEmail.TextBody = "Body"                                  'Message Text
objEmail.BodyPart.Charset = "windows-1251"                    'Cyrillic encoding
'Sending message using SMTP-service (1 - using of local SMTP-service)
objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name of SMTP-server
objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "smtp.server.ru"
objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = 2
objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusername") = ""
objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendpassword") = ""
'objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25  'Port of SMTP-server
objEmail.Configuration.Fields.Update           'Update configuration of CDO-object
objEmail.Send    'Sending of message by using Send-method
Часовой пояс GMT +3, время: 16:16.
