Старый 28.12.2015, 10:11   #1
palleagermark: Working with Excel files in AX7
Источник: http://www.agermark.com/2015/12/work...es-in-ax7.html
To work with Excel files from code, Microsoft now suggests using the EPPlus .NET library.
EPPlus 4.04 (http://epplus.codeplex.com) is available to X++ via AOT/References/EPPlus.
There is an example of usage in AOT/Code/Classes/CustCollectionsExcelStatement.
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
Gareth Tucker: Scribe Insight and Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.05.2012 02:18
palleagermark: Working with files that are supplied by or generated for clients Blog bot DAX Blogs 0 22.08.2011 17:11
Часовой пояс GMT +3, время: 03:20.
