Старый 14.12.2015, 22:11   #1
mfp: X++ in AX7: Reals are decimals
Источник: http://blogs.msdn.com/b/mfp/archive/...-decimals.aspx
In AX2012 reals are compiled as System.Decimal when compiling IL code. In AX7 that is the only option.
The main difference between the two is the maximum value supported:
AX 2012:
AX 7:
~ 9E127
~ 8E28
Both numbers should be large enough for most ERP scenarios – but you could get burned when doing arithmetic.
For example in AX7 you get an "Value was either too large or too small for a Decimal" exception when multiplying big reals - like realMax()
In AX 2012 the above would be within the supported range.
Another related improvement is that you now can control the number of decimals when Real based Extended Data Types are persisted in the data base, and the default is now 6 decimals – but that is another story.
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 TECHNICAL PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
mfp: X++ in AX7: Client/Server keywords Blog bot DAX Blogs 23 15.12.2015 09:09
mfp: X++ in AX7: Static event subscription Blog bot DAX Blogs 0 11.12.2015 11:11
mfp: X++ in AX7: Private and public members Blog bot DAX Blogs 12 10.12.2015 09:08
mfp: X++ in AX7: The var keyword Blog bot DAX Blogs 43 04.12.2015 10:19
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
Часовой пояс GMT +3, время: 18:22.
