Axapta
Цитата из Sure Step:
Fit Gap should be part of 5, 10 or 15 day Implementing Microsoft Dynamic AX planning Services engagement. This phase should only be performed after the assessment phased was performed during the first 3 days of the engagement.
Fit Gap Analysis Tasks
Review the Customer Requirements in the Business Solution 1. Confirm and document as a Fit any business processes that can be run by using the business management solution. 2. Standard Features and Configuration settings and setup option values should be documented. 3. Define the importance/priority which the Customer has identified for all the requirements. Document Gaps Between the Customer Requirements and Business Solution 1. Document Gaps for those business processes that cannot run completely by using the business solution. 2. Capture the nature and details of the Gaps and use examples where needed. Analyze Gaps and Identify Solutions or Workarounds 1. Investigate resolutions or workarounds 2. Decide on the appropriate resolution 3. Update business processes documentation if needed. 4. Discuss resolution options with the Customer. Document Gaps, Resolutions and Workarounds |
За это сообщение автора поблагодарили: mnt_dx (2). |
Теги |
специальная олимпиада, человек-баттхёрт |
Тема | Ответов | |||
Русские: особенности национального общения | 5 | |||
Сайт, более удобный и для общения, и для нетворкинга | 23 | |||
Рацпредложение по эффективизации общения | 11 | |||
Windows | 1 |
Опции просмотра | |
