kurthatlevik: DAX2012R3CU9 – DIXF – Automate import/export without customizations
Источник: https://kurthatlevik.wordpress.com/2...ustomizations/
============== The Microsoft Dynamics AX 2012 Data Import/Export Framework(DIXF) is an AX module import and export data in Microsoft Dynamics AX. We often use it in data migration projects to load legacy data from old systems. I was wondering if I could use DIXF as an automated integration, without any customizations. I wanted to see if I could have a folder where new customers are dropped in a folder, and then the DIXF automatically picked up the file, and imported it. My first step is to have a small and minimalistic Excel sheet, that users can paste in the new customer records. This is how my Excel sheet looks like: Most of these customers exists from before, but the last record is a new customer that don’t exists in my database. ![]() The recommended process of setting up an import/export process is described here. ![]() The first step is to create a source data format: ![]() I then determine what entity to use, and create a target entity ![]() When I do this, the mapping is done automatically for me, and I don’t have to understand all the database related complexity. My next step is to create the processing group ![]() I then click on the Entities in the processing group, and I select my created entity and that I want to use my created Excel source data format. I also select a sample file to see if the mapping is OK. ![]() I then just check the mapping from Excel to the staging format, and make the necessary corrections. ![]() My next step is to go back to the processing group, and to make the necessary batch job for automatic processing. ![]() As you see here, I set the “type” to Directory, that DIXF will scan for new files. I also specify directories for processing, completed and error. I have therefore created the following directory structure for each integration: ![]() The other important thing is the “Execute target step”. This this used for also executing the step that transfers data from the staging table to the target tables. I then want this to be work in batch, so I enable the batch processing. ![]() And then I need to wait for an entire minute……… I then saw that the file was moved from the 1_new folder, and ended up in the ¤_Completed folder. ![]() I also see in the execution history, that the files was imported into the staging tables, and then imported into the target tables. ![]() In my customer overview, I now see that I have a new customer, but is also made sure that other related data as addresses, and phone etc was created. ![]() This concludes how you can use DIXF to automatically import data. What I can now do to import data, is just to create my Excel file, and then dump it into the right folder (.\1_New), and then the batch system take care of the test. If you wonder all entities that are “out-of-the-box” supported from Microsoft, then take a look here. If still something is missing, you can always ask a developer to assist in creating the DIXF entities you need. Happy DIXF’ing J ![]() Источник: https://kurthatlevik.wordpress.com/2...ustomizations/
Теги |
dixf |
