Microsoft Dynamics CRM Team Blog: PowerShell module for performing data operations and manipulating user and system settings in CRM
Источник: http://blogs.msdn.com/b/crm/archive/...gs-in-crm.aspx
============== Did you ever wish to perform all these operations in Microsoft Dynamics CRM using PowerShell:
Introducing Microsoft.Xrm.Data.PowerShell module for CRM, created by Kenichiro Nakamura and Sean McNellis, which provides you a single PowerShell module with over 60 PowerShell functions to perform data operations in CRM and manipulate user and system settings. The module is built using the Microsoft.Xrm.Tooling.CrmConnector.PowerShell snap-in, and the two XRM Tooling PowerShell cmdlets (Get-CrmOrganizations and Get-CrmConnection) are also part of this module. The Microsoft.Xrm.Data.PowerShell module for CRM works with CRM online and CRM 2013 and later (on-premises). To use this module, you require PowerShell 4.0 or later. After you have downloaded and imported the Microsoft.Xrm.Data.PowerShell module on your computer:
For detailed information about the module, and how to import and use it, see Microsoft.Xrm.Data.PowerShell module for CRM. We look forward to your feedback, and will be adding more PowerShell functions in the coming days. Kenichiro Nakamura, Sr. Premier Mission Critical Specialist, is based out of Japan and works supporting PMC customers. Sean McNellis, Sr. Premier Field Engineer, is based out of North America and works supporting Dynamics CRM customers. Blog (English): http://blogs.msdn.com/CrmInTheField Blog (Japanese): http://blogs.msdn.com/CrmJapan Twitter: @pfedynamics Источник: http://blogs.msdn.com/b/crm/archive/...gs-in-crm.aspx
| Тема | Ответов | |||
| emeadaxsupport: New Content for Microsoft Dynamics AX 2012 : October 2011 | 0 | |||
