Чувак напилил уже кучу статей с картинками по импорту разных данных через DIXF.
http://shafeaa.blogspot.co.nz/p/di.html Import Data From an ODBC Through DIXF Convert Field Values During The Importing Process Through DIXF Assign Default Values Automatically During the importing process through DIXF Assign Default Values Automatically During the importing process through DIXF Configure DIXF To Automatically Generate Unique Key Using Number Sequence Importing purchase orders using DIXF Import Released products using DIXF Import Projects using Data Import framework AX 2012 R3 Import Workers using Data Import framework AX 2012 R3 Import Assets using Data Import framework | AX 2012 R3 Import Vendor Groups using Data Import framework | AX 2012 R3 Import Main Accounts using Data Import framework | AX 2012 R3 Import Vendors using Data Import framework | AX 2012 R3 Import Customers using Data Import framework | AX 2012 R3 Import Financial Dimension using Data Import framework | AX 2012 R3 |
| За это сообщение автора поблагодарили: AlGol (1), trud (2), sukhanchik (4), Logger (3), Ace of Database (3), Raven Melancholic (2), Ivanhoe (5), gl00mie (3), Stitch_MS (3), G.Menshikh (1), Kabardian (2), pedrozzz (2). | |
| Теги |
| dixf, import, integration, r3, ax2012 |
