Старый 23.07.2015, 13:46   #1
raniel is offline
raniel
Аватар для raniel
241 / 11 (1) +
Через отдельный класс. Простенький сервис. На входе один атрибут на выходе 3 параметра(типы простые).
Старый 23.07.2015, 13:52   #2
Dreadlock is offline
Dreadlock
Аватар для Dreadlock
298 / 224 (8) ++++++
А вы сделали как написано тут:
The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework SDK documentation and inspect the server trace logs."
Т.е. Нажмите на изображение для увеличения
Старый 23.07.2015, 14:07   #3
raniel is offline
raniel
Аватар для raniel
241 / 11 (1) +
Да сделал. И получил подробности ошибки ... когда нажимаю вторую ссылку http://xxx.xxxxx.ru/MicrosoftDynamic...svc?singleWsdl получаю вот такой ответ
The service encountered an error.
An ExceptionDetail, likely created by IncludeExceptionDetailInFaults=true, whose value is:System.NotSupportedException: A single WSDL document could not be generated for this service. Multiple service contract namespaces were found (http://schemas.microsoft.com/netfx/2009/05/routing, http://tempuri.org). Ensure that all your service contracts have the same namespace. at System.ServiceModel.Description.WsdlHelper.VerifyContractNamespace(List`1 wsdls) at System.ServiceModel.Description.WsdlHelper.GetSingleWsdl(MetadataSet metadataSet) at System.ServiceModel.Description.ServiceMetadataExtension.EnsureSingleWsdlInitialized() at System.ServiceModel.Description.ServiceMetadataExtension.HttpGetImpl.TryHandleMetadataRequest(Message httpGetRequest, String[] queries, Message& replyMessage) at System.ServiceModel.Description.ServiceMetadataExtension.HttpGetImpl.ProcessHttpRequest(Message httpGetRequest) at SyncInvokeGet(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage31(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
401, service, soap, сервис
Проблема балансировки в кластере AOS Ivanhoe DAX: Администрирование 26 29.07.2015 16:19
workflowax: The Request Failed with HTTP status 401: Unauthorized Blog bot DAX Blogs 0 20.09.2011 23:12
emeadaxsupport: HTTP 401 Error when trying to deploy/create an Enterprise Portal site on a load balanced farm using a hardware load balancer Blog bot DAX Blogs 0 06.05.2010 03:16
Проблема с созданием объекта Lelya DAX: Администрирование 33 27.06.2005 16:38
Проблема: русские шрифты в отчетах, формируемых на сервере. Anais DAX: Администрирование 3 17.11.2003 13:20
Часовой пояс GMT +3, время: 15:56.
