Старый 29.05.2015, 15:11   #1
emeadaxsupport: Releasing a Product to other companies during DIXF product import
Источник: http://blogs.msdn.com/b/axsupport/ar...ct-import.aspx
For the AX 2012 R2/R3, there is a field in the staging table called ReleaseProductCompany.
This field is used to release the product to multiple companies; it will do the same as manually release the product.
On the Source data format you can specify a Multi value separator. Using this character you can specify multiple company values.
You need to add a column into your import file for the”ReleaseProductCompany” field and define what additional
companies you want the product to be released on during the DIXF product import.
Responsible code is in \Classes\DMFProductEntityClass\insertUpdate
Старый 29.05.2015, 17:47   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Круто, только вот этот кусок кода расстроил:
changecompany(companyInfo.DataAreaId)
    if (!InventTable::find(target.ItemId))
        res = true;
changecompany - дико тормозная операция, противопоказанная массовым импортам. Лучше напрямую выбирать запись в нужной компании:
conDataAreaId = [companyInfo.DataAreaId];
if ((select firstonly crosscompany:conDataAreaId RecId from InventTable where InventTable.ItemId == target.ItemId).RecId == 0)
    res = true;
DynamicsAxSCM: Understanding the product validation process in Dynamics AX 2012 Blog bot DAX Blogs 0 07.12.2012 03:12
emeadaxsupport: How to import default site and warehouse locations for a product using services (AIF) Blog bot DAX Blogs 0 10.07.2012 00:11
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part III Blog bot DAX Blogs 0 17.05.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part II Blog bot DAX Blogs 0 11.05.2011 06:15
Часовой пояс GMT +3, время: 12:07.
