Старый 20.11.2014, 07:59   #1
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Features
Toolbuttons
  • From left to right:
  • Tile horisontal (places 2 last activated windoz side by side)
  • Show type hierarchy
  • Show cross references
  • Show list of classes, where selected method in aot was overriden
  • Copy AOT path of selected node to clipboard (hold shift to copy name of the node only)
  • Table browser
  • Open application object (for example, if you have opened method it opens class or form of that method)
  • Find in AOT
Task bar
  • colored tabs
  • middle click closes tab
  • has context menu (right click on tab to see)
  • supports drag & drop of tabs
Input box
  • type full path of AOT node and press enter to open the node
  • type name of the node to open node ot menu of node with the same name
  • type ?<expression> to evaluate X++ expression value (for example ?tableID2Name(13))
  • type !<statement> to run X++ statement (for example !ExchRates::flushClient())
  • type <class>.<method> to open method of a class, for example infolog.add
Autorun
  • to run DEV_Toolbar on start of ax client add line "-startupcmd=Autorun_c:\work\jobs\dev_toolbar.xml" (without quotes and changing path to where you extracted archive) to:
  • shortcut of Ax32.exe
  • or to client configuration parameters
  • or to AxLauncher configuration
Extensibility
to add a button create AOT resorce with name like DEV_Toolbar_<menuItemType>_<menuItemName> and contents 16x16 png image of button. See DEV_Toolbar_Display_SysAotFind resource as an example
Миниатюры
Последний раз редактировалось belugin; 20.11.2014 в 08:02.
code review, lifecycle services
Удобство чтения кода - залог и определенная гарантия его работоспособности sukhanchik DAX: Программирование 29 11.04.2013 10:52
Небольшой тюнинг редактора кода AX2012 kart DAX: Программирование 6 22.02.2013 17:21
axforum blogs: О заполнении Наименования и Кода номенклатуры в печатной форме Накладной (Ax2009 ru7) Blog bot DAX Blogs 0 07.06.2011 09:11
проблема с настройкой штрихового кода Nic DAX: Функционал 4 27.12.2004 09:04
Использование штрихового кода (barcode) в Аксапта Pavlo AKA Panok DAX: Функционал 9 17.10.2003 15:13
Часовой пояс GMT +3, время: 06:17.
