Старый 02.09.2014, 14:37   #10
Kipetcoff is offline
Kipetcoff
Сообщение от slivka_83 Посмотреть сообщение
http://support.microsoft.com/kb/2691237
An example of a CRM Online configuration file:
Пытаюсь настроить фильтрацию латинскими буквами, но безуспешно. Мудреная больно конфигурация подключения. У меня облачный CRM. Настроил конфу.
Код:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
    <configSections>
        <sectionGroup name="applicationSettings" type="System.Configuration.ApplicationSettingsGroup, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" >
            <section name="OrgDBOrgSettingsTool.Properties.Settings" type="System.Configuration.ClientSettingsSection, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" requirePermission="false" />
        </sectionGroup>
    </configSections>
    <applicationSettings>
        <OrgDBOrgSettingsTool.Properties.Settings>
            <setting name="OrgDBOrgSettingsTool_CrmService_CrmService" serializeAs="String">
              <!--- Please change CrmServer to your Crm Server Name -->
                <value>https://xxxx.crm4.dynamics.com/MSCrmServices/2007/CrmService.asmx</value>
            </setting>
            <setting name="OrgDBOrgSettingsTool_CrmDiscoveryService_CrmDiscoveryService"
                <value>https://xxxx.crm4.dynamics.com/XrmServices/2011/Discovery.svc</value>
            </setting>
            <setting name="OrgDBOrgSettingsTool_SKU" serializeAs="String">
              <!--- Possible values here are Online/Office365/SPLA/OnPrem -->
                <value>Online</value>
            </setting>
            <setting name="OrgDBOrgSettingsTool_UserName" serializeAs="String">
              <!--- Please change the value below to your email Id/User Name for Online / SPLA -->
                <value>sokolov@xxxx.onmicrosoft.com</value>
            </setting>
          <setting name="OrgDBOrgSettingsTool_Domain" serializeAs="String">
            <value>xxxx.onmicrosoft.com</value>
          </setting>
          <setting name="OrgDBOrgSettingsTool_OrgServiceUri" serializeAs="String">
            <value>https://{0}.crm4.dynamics.com/XrmServices/2011/Organization.svc</value>
          </setting>
          <setting name="OrgDBOrgSettingsTool_RegistrationEndPointUri" serializeAs="String">
            <value>https://login.live.com/ppsecure/DeviceAddCredential.srf</value>
          </setting>
            <setting name="OrgDBOrgSettingsTool_Partner" serializeAs="String">
              <!--- This is applicable only for Online -->
                <value>Crm.Dynamics.com</value>
            </setting>
            <setting name="OrgDBOrgSettingsTool_Environment" serializeAs="String">
                <value></value>
            </setting>
        </OrgDBOrgSettingsTool.Properties.Settings>
    </applicationSettings>
</configuration>
А в ответ мне
Что за ерунда? О чем это вообще? У меня есть подозрение, что это из-за того, что у пользователя нет учетки в live, но в CRM же у него учетка есть.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 15 Blog bot Dynamics CRM: Blogs 1 10.02.2016 10:26
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 00:47.
