Старый 28.08.2014, 19:11   #1
palleagermark: My new best friend: Set-AXModelStore -InstallMode
Источник: http://www.agermark.com/2014/08/my-n...odelstore.html
I'm working on an upgrade from AX 2012 R2 to AX 2012 R3, and during the initial work upgrading the code I experience from time to time that the client crashes. To be fair we probably have modifications in places we shouldn't have them, though I have removed the worst before starting the upgrade.
The problem is that when I restart the client, I get an empty workspace and the menu item to open a new development workspace is disabled.
Panic sets in and my pulse rate gets alarming high, but...
Manually setting the model store in installation mode again and restarting the client opens the "The model store has been modified" dialog and I'm able to open a development workspace again.
So if that happens to you, try to open the Microsoft Dynamics AX 2012 Management Shell and enter the command "Set-AXModelStore -InstallMode".
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
palleagermark: Parsing a custom parameter from a user control to a data set used on another user control Blog bot DAX Blogs 0 28.10.2010 12:05
palleagermark: Data Set lookups on Enterprise Portal (EP) Blog bot DAX Blogs 0 20.12.2009 11:06
palleagermark: Bug in EP 2009 when having the debug flag set to true Blog bot DAX Blogs 0 05.01.2009 11:06
palleagermark: Set focus on a particular field on an EP page Blog bot DAX Blogs 0 27.11.2008 14:05
Часовой пояс GMT +3, время: 12:19.
