Старый 15.05.2014, 15:11   #1
atinkerersnotebook: Split Your Number Sequences To Make Them Look Intelligent
Источник: http://atinkerersnotebook.com/2014/0...k-intelligent/
Originally posted on Dynamics AX Tip Of The Day:
The Number Sequences within Dynamics AX are great because they allow you to add a lot of intelligence to your document and transaction numbering. You can add constants to them so that you can quickly see where they came from and sort though them. But it doesn’t stop there. If you have incorporated some logic into how you are actually numbering the records, then you can split the number up itself so that even though it’s still continuous, there may be segment separators that highlight that certain numbers are significant.Now you just need to train the users on what the numbers mean…
View original 308 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Часовой пояс GMT +3, время: 22:25.
