Старый 23.04.2014, 17:46   #1
Lavdislav is offline
Lavdislav
А код bf_PluginProcess? В конструкторе ведь наверняка TargetEntity заполяете...
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Microsoft.Xrm.Sdk.Messages;
using Microsoft.Xrm.Sdk.Metadata;
using Microsoft.Xrm.Sdk;
using Microsoft.Xrm.Sdk.Query;
namespace Bum.Survey.CRM.Plugin.BaseLib
    public static class MessageName
        public const string Create = "Create";
        public const string Update = "Update";
        public const string Delete = "Delete";
        public const string RetrieveMultiple = "RetrieveMultiple";
        public const string Retrieve = "Retrieve";
    public static class ParameterName
        public const string Target = "Target";
        public const string id = "id";
        public const string Query = "Query";
        public const string BusinessEntityCollection = "BusinessEntityCollection";
        public const string BusinessEntity = "BusinessEntity";
    public class bf_PluginError : Exception
        public bf_PluginError(string message)
            : base(message)
    public abstract class bf_PluginProcess
        IServiceProvider _serviceProvider;
        public IServiceProvider serviceProvider
            get { return _serviceProvider; }
        IPluginExecutionContext _executionContext;
        public IPluginExecutionContext executionContext
            get
                if (_executionContext == null)
                    _executionContext = (IPluginExecutionContext)serviceProvider.GetService(typeof(IPluginExecutionContext));
                return _executionContext;
        IOrganizationServiceFactory _serviceFactory;
        public IOrganizationServiceFactory serviceFactory
            get
                if (_serviceFactory == null)
                    _serviceFactory = (IOrganizationServiceFactory)serviceProvider.GetService(typeof(IOrganizationServiceFactory));
                return _serviceFactory;
        IOrganizationService _crmService;
        public IOrganizationService crmService
            get
                if (_crmService == null)
                    _crmService = serviceFactory.CreateOrganizationService(executionContext.UserId);
                return _crmService;
        ITracingService _tracingService;
        public ITracingService tracingService
            get
                if (_tracingService == null)
                    _tracingService = (ITracingService)serviceProvider.GetService(typeof(ITracingService));
                return _tracingService;
        public bf_PluginProcess(IServiceProvider serviceProvider)
            _serviceProvider = serviceProvider;
        Entity _entity;
        public Entity TargetEntity
            get
                return _entity;
        EntityReference _entity_key;
        public EntityReference TargetKey
            get { return _entity_key; }
        public void LoadEntity()
            if (executionContext.InputParameters.Contains(ParameterName.Target))
                if (executionContext.InputParameters[ParameterName.Target] is Entity)
                    _entity = (Entity)executionContext.InputParameters[ParameterName.Target];
                    _entity_key = new EntityReference(_entity.LogicalName, _entity.Id);
                else if (executionContext.InputParameters[ParameterName.Target] is EntityReference)
                    _entity_key = (EntityReference)executionContext.InputParameters[ParameterName.Target];
            if (executionContext.MessageName == MessageName.Create)
                if (executionContext.OutputParameters.Contains(ParameterName.id))
                    _entity_key.Id = (Guid)executionContext.OutputParameters[ParameterName.id];
        public void RequeryTarget()
            RequeryTarget(new ColumnSet(true));
        public void RequeryTarget(ColumnSet columnSet)
            _entity = crmService.Retrieve(TargetKey.LogicalName, TargetKey.Id, columnSet);
        public bool ValidateEntityName(string logicalName)
            return _entity_key.LogicalName == logicalName;
        public bool ValidateMessage(params string[] messages)
            return messages.Contains(executionContext.MessageName);
        abstract public void Execute();
        public void Run()
            try
                Execute();
            catch (System.Exception ex)
                throw new InvalidPluginExecutionException(
                    String.Format("An error occurred in the {0} plug-in: {1}", this.GetType().ToString(), ex.ToString()), ex);
        public Dictionary<int, string> GetOptionSet(string entityName, string optionSetName)
            RetrieveAttributeRequest req = new RetrieveAttributeRequest();
            req.EntityLogicalName = entityName;
            req.LogicalName = optionSetName;
            RetrieveAttributeResponse res = (RetrieveAttributeResponse)_crmService.Execute(req);
            Dictionary<int, string> result = new Dictionary<int, string>();
            foreach (var r in ((PicklistAttributeMetadata)res.AttributeMetadata).OptionSet.Options)
                result.Add(r.Value.Value, r.Label.UserLocalizedLabel.Label);
            return result;
    public static class DateTimeExt
        public static string ConvertToCulturalString(this DateTime dt)
            return dt.ToLocalTime().ToString("dd.MM.yyyy");
Старый 23.04.2014, 18:08   #2
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Мда. Зачем таким образом плагины писать - мне умом не понять (хотя я в CRM пришёл из мира ООП и немного в этом понимаю), но то ваше дело.
Суть в чём - как я и писал у вас не заполняется _entity. И соответственно проперти TargetEntity отдаёт null. Отсюда и ошибка.
А вообще - учитесь дебажить плагины через VS.
За это сообщение автора поблагодарили: Lavdislav (1).
Старый 24.04.2014, 10:25   #3
Lavdislav
Хорошо, попробую разобратся с этим PreImage
Старый 24.04.2014, 10:54   #4
Lavdislav
Вроде и preimage сделал, в коде тож добавил, но ругается так и так на ту же ошибку...
if (executionContext.MessageName == MessageName.Delete)
                if (executionContext.PreEntityImages.Contains("Target") && executionContext.PreEntityImages["Target"] is Entity)
                    Entity preMessageImage = (Entity)executionContext.PreEntityImages["Target"];
                    QueryExpression surveyz = new QueryExpression()
                        EntityName = "bf_survey",
                        ColumnSet = new ColumnSet(true)
                    surveyz.Criteria.AddCondition("bf_surveyid", ConditionOperator.Equal, preMessageImage.GetAttributeValue<EntityReference>("bf_surveytoken_survey").Id);
                    List<Entity> surveylists = crmService.RetrieveMultiple(surveyz).Entities.ToList();
                    foreach (var surveylist in surveylists)
                        QueryExpression token = new QueryExpression()
                            EntityName = "bf_surveytoken",
                        token.Criteria.AddCondition("bf_surveytoken_survey", ConditionOperator.Equal, surveylist.Id);
                        List<Entity> surveyTokens = crmService.RetrieveMultiple(token).Entities.ToList();
                        surveylist["bf_survey_tkcnt"] = surveyTokens.Count - 1;
                        crmService.Update(surveylist);
Я хоть на правильном пути?
Изображения
Старый 24.04.2014, 11:01   #5
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Повторюсь. Учитесь отлаживать плагины.
Старый 24.04.2014, 11:46   #6
Lavdislav
Ок.
Подсчет количества записей , требуется подсказка filo Dynamics CRM: Разработка 2 19.06.2013 10:39
Ошибка массовой загрузки связанных записей Артем Enot Грунин Dynamics CRM: Функционал 0 08.11.2012 09:31
axforum blogs: Параметр TotalRecordCount и проблемы производительности. Как отключить подсчет количества записей в представлении Blog bot Dynamics CRM: Blogs 0 13.06.2012 22:11
Подсчет всех записей со всех страниц lin2nil Dynamics CRM: Функционал 21 08.12.2011 11:02
Фильтр для отчета - из списка связанных записей? AlekseyS Dynamics CRM: Разработка 3 11.09.2008 10:54
Часовой пояс GMT +3, время: 14:10.
