Leon's CRM Musings: A Codeless Rollup Field
Источник: http://leontribe.blogspot.com/2013/1...lup-field.html
============== I owe this tip to my fellow CRM partner-in-crime, Oakton Canberran Julie Stedman who discovered it on a project we are working on. It works for both CRM 2011 and CRM 2013. The Problem Often a client asks to roll up the number of child records to a parent record or, perhaps, roll them up and split them by status. An example may be enrolments for a course. On the course record we want to see the number of enrolments and whether the attendees have paid. Traditionally, we add a field to the parent record and use a plugin to query CRM to populate the value in the field. However, there is another way. The Solution A little-known property of adding a sub-grid to a form is the ability to only show a chart instead. This means we can add a bar chart or pie chart to a record showing totals for the child records. Scroll down to the bottom on the sub-grid properties for the magic tickbox to ‘Show Chart Only’. ![]() That is it. With this ticked, instead of a grid showing, you see a chart which represents whatever related data you desire. Here is an example where I have added the chart to a Case record to summarise the associated activities. ![]() The only drawback with this is you cannot drill down into the chart but, for rollup totals, this is probably not the end of the world. Conclusions For a quick and elegant way to show rollup totals of child records on a parent record, consider this trick. You still have the power to configure the look and feel of the chart(s) and you avoid adding a bunch of fields and populating them via plugins which can be time-consuming and, therefore expensive. Источник: http://leontribe.blogspot.com/2013/1...lup-field.html
Опции просмотра | |
