Старый 04.10.2013, 12:11   #1
kamalblogs: Productivity tip: Do you need the under score when naming – Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2013...g-dynamics-ax/
Well When we sat through the product review there was one simple point that caught our attention, surprisingly it helped us improve our productivity. This post is to share on what we learnt.
Typically i have seen several implementation and product development teams adopting the ‘_’(underscore) naming convention. In fact we followed it through out Dynamics AX 2009. Though at the very first look it appears helpful in hindsight it deters productivity.
How ?
1. While you type holding a shift key is not making typing faster.
2. Every time you declare a variable you are again held up with underscores
3. On the AOT node navigating is definitely not easier.
If you look all these points at a component level it can be ignored but when you do it over and over it adds up to a significant time.
Next time you start a new project or product consider if you need to use the underscore ‘_’ again.
Related articles
kamalblogs: SSRS Tip: Speed up RDP based SSRS reports testing in Dynamics Ax 2012 Blog bot DAX Blogs 0 11.09.2013 17:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 08:48.
