Старый 24.06.2013, 16:08   #1
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Alex_KD - 10 points!
Сказал Visual Studio "Generate async. calls", написал вот такой код - работает!
Код:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO;
namespace VendGroupUpdate
    class Program
        static void Main(string[] args)
            VendGroupService.CallContext                context = new VendGroupService.CallContext();
            VendGroupService.EntityKey[]                keys;
            VendGroupService.KeyField                   keyField;
            VendGroupService.AxdVendGroup               vendGroup;
            DateTime        timeNow;
            IAsyncResult    result;
            int i;
            AsyncCallback cb = new AsyncCallback(Program.VendGroupCallback);
            context.Company = "USMF";
            for (i = 1; i <= 1000; i++) // Try 1000 parallel calls
                VendGroupService.VendGroupServiceClient client = new VendGroupService.VendGroupServiceClient();
                client.ClientCredentials.Windows.AllowedImpersonationLevel = System.Security.Principal.TokenImpersonationLevel.Anonymous;
                keys = new VendGroupService.EntityKey[1];
                keys[0] = new VendGroupService.EntityKey();
                keyField = new VendGroupService.KeyField();
                keyField.Field = "VendGroup";
                keyField.Value = "10";
                keys[0].KeyData = new VendGroupService.KeyField[1] { keyField };
                vendGroup = new VendGroupService.AxdVendGroup();
                vendGroup.VendGroup = new VendGroupService.AxdEntity_VendGroup[1];
                vendGroup.VendGroup[0] = new VendGroupService.AxdEntity_VendGroup();
                vendGroup.VendGroup[0].VendGroup = "10";
                vendGroup.VendGroup[0].Name = i + " " + System.DateTime.Now.ToShortTimeString();
                vendGroup.VendGroup[0]._DocumentHash = "XYZ";
                vendGroup.VendGroup[0].action = VendGroupService.AxdEnum_AxdEntityAction.replace;
                try
                    timeNow = System.DateTime.Now;
                    Console.WriteLine("Start call " + i);
                    //client.update(context, keys, vendGroup);
                    result = client.Beginupdate(context, keys, vendGroup, null/*cb*/, client);
                    Console.WriteLine("Call ended. Acknowledge: " + result.AsyncState.ToString());
                    Console.WriteLine("Delay: " + (-timeNow.Subtract(System.DateTime.Now)).ToString());
                catch (Exception e)
                    Console.WriteLine("Exception: " + e.Message);
                    client.Abort();
                //client.Close();
            Console.ReadKey();
        public static void VendGroupCallback(IAsyncResult ar)
            VendGroupService.VendGroupServiceClient client = (VendGroupService.VendGroupServiceClient) ar.AsyncState;
            client.Endupdate(ar);
            Console.WriteLine("Callback fired.");
На самом деле это - симуляция, конечно. На сервер отправляется Request, .NET держит сессию и делает где-то в своих глубинах цикл, потом вызывает функцию Callback по указателю, передавая ей Response.
Последний раз редактировалось EVGL; 24.06.2013 в 17:52.
aif, ax2012, azure service bus, document service, service, законченный пример, производительность
emeadaxsupport: Announcing a Major Update to RapidStart Services Online Help Blog bot DAX Blogs 0 21.03.2013 20:11
emeadaxsupport: AX2012 AIF services error - The maximum number of joins allowed (99) is exceeded in the statement. Blog bot DAX Blogs 1 03.07.2012 08:13
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
gatesasbait: Installing Reporting Services, Analysis Services and Enterprise Portal for AX 2009 Blog bot DAX Blogs 0 03.07.2008 02:05
Часовой пояс GMT +3, время: 09:31.
