Старый 20.06.2013, 12:36   #1
dech is offline
dech
Аватар для dech
Самостоятельные клиенты AX
650 / 352 (13) ++++++
Снова такая же проблема возникла. Теперь же не могу понять в чем дело... Получается, будто условие в принципе не срабатывает и всегда возвращает TRUE.
    Query                   q = new Query();
    QueryRun                qr;
    QueryBuildDataSource    qbds;
    QueryBuildRange         qbr;
    int                     expDays = 30;
    int                     division = Dimensions::code2ArrayIdx(SysDimension::Division);
    InventTable                 it;
    InventSerialProperties   isp;
    date                        expDate;
    qbds = q.addDataSource(tablenum(InventTable), tablestr(InventTable));
    qbds.addRange(fieldid2ext(fieldnum(InventTable, Dimension), division)).value('FSM');
    qbds = qbds.addDataSource(tablenum(InventSum));
    qbds.addLink(fieldnum(InventTable, ItemId), fieldnum(InventSum, ItemId));
    qbds.addRange(fieldnum(InventSum, PhysicalInvent)).value(">0");
    qbds.addRange(fieldnum(InventSum, ItemId)).value("C250");
    qbds = qbds.addDataSource(tablenum(InventDim));
    qbds.addLink(fieldnum(InventSum, InventDimId), fieldnum(InventDim, InventDimId));
    qbds = qbds.addDataSource(tablenum(InventSerial));
    qbds.addLink(fieldnum(InventDim, InventSerialId), fieldnum(InventSerial, InventSerialId));
    qbds = qbds.addDataSource(tablenum(InventSerialProperties), tablestr(InventSerialProperties));
    qbds.addLink(fieldnum(InventSerial, InventSerialId), fieldnum(InventSerialProperties, InventSerialId));
    qbr = qbds.addRange(fieldnum(InventSerialProperties, DataAreaId));
    // Задаем такое условие: InventSerialProperties.StretchDate + InventTable.ShelfLife <= now() + expDays
    qbr.value(strfmt("(%1.%2 + %3.%4 <= %5)", // здесь условие срабатывает в любом случае
        tablestr(InventSerialProperties),
        fieldstr(InventSerialProperties, StretchDate),
        tablestr(InventTable),
        fieldstr(InventTable, ShelfLife),
        date2strxpp(systemdateget() + expDays)
    // Pulling data
    qr = new QueryRun(q);
    while (qr.next())
        it = qr.get(tablenum(InventTable));
        isp = qr.get(tablenum(InventSerialProperties));
        expDate = isp.StretchDate + it.ShelfLife;
        info(date2strxpp(expDate) + " <= " + date2strxpp(systemdateget() + expDays));
То же самое на SQL. Здесь, конечно все работает:
DECLARE @ExpDays INT
SET @ExpDays = 1
SELECT
    ISum.ItemId
  , ISum.PhysicalInvent
  , InvD.ConfigId
  , InvD.InventColorId
  , InvD.WMSLocationId
  , InvD.InventBatchId
  , InvD.InventLocationId
  , InvD.WMSPalletId
  , InvD.AFCInventContainerId
  , InvD.InventSerialId
  , ISP.StretchDate
  , DATEADD(DD, InvT.SHELFLIFE, ISP.StretchDate) AS ExpirationDate
FROM InventTable InvT
INNER JOIN InventSum ISum
   ON ISum.DataAreaId = InvT.DataAreaId
  AND ISum.ItemId = InvT.ItemId
INNER JOIN InventDim InvD
   ON InvD.DataAreaId = ISum.DataAreaId
  AND InvD.InventDimId = ISum.InventDimId
INNER JOIN InventSerial ISer
   ON ISer.DataAreaId = InvD.DataAreaId
  AND ISer.InventSerialId = InvD.InventSerialId
INNER JOIN InventSerialProperties ISP
   ON ISP.DataAreaId = ISer.DataAreaId
  AND ISP.InventSerialId = ISer.InventSerialId
WHERE InvT.DataAreaId = 'dat'
  AND InvT.Dimension3_ = 'FSM'
  AND ISum.ItemId = 'C250'
  AND ISum.PhysicalInvent > 0
  AND ISP.StretchDate + InvT.ShelfLife <= GETDATE() + @ExpDays
// no comments
Последний раз редактировалось dech; 20.06.2013 в 13:16.
ax-erp: How to Set the Query Range on a SSRS Report Blog bot DAX Blogs 0 18.10.2012 19:11
sumitax: AX Queries – Passing query range as parameter Blog bot DAX Blogs 0 29.06.2011 13:11
Advanced query range value expressions: поле таблицы - имя вcтроенной функции year(). ATimTim DAX: Программирование 12 27.03.2009 18:16
axaptafreak: Label for Query Range cannot be modified (still) Blog bot DAX Blogs 2 25.07.2007 10:09
Advanced query range value expressions dn DAX: Программирование 2 07.10.2003 15:38
Часовой пояс GMT +3, время: 15:15.
