| Результаты опроса: Scrum, Agile это хорошая штука? | |||
| А что это вообще такое? |      | 6 | 33.33% |
| хорошая |      | 10 | 55.56% |
| плохая |      | 0 | 0% |
| не для Microsoft Dynamics |      | 2 | 11.11% |
| Голосовавшие: 18. Вы ещё не голосовали в этом опросе | |||
|  | Опции темы |
|  13.06.2013, 12:54 | #1 |
| Axapta |
			Я на всякий случай оставлю тут информацию из Sure Step о том, когда по мнению MS имеет смысл применять данную методологию. Цитата:
			Purpose The Agile project type represents a flexible and collaborative approach to implementing Microsoft Dynamics Solutions at a single site requiring specific features and moderate-to-complex customizations. Description The Agile Project Type is associated with an iterative, incremental process for developing Microsoft Dynamics Solutions. This Project Type gives customers greater control over the final solution because they can quickly change the direction of solution development and implementation from one sprint cycle to the next. This means that they are better placed to respond to their businesses needs as development of the solution progresses. This Project type can be attractive to customers, but it does come with its own set of risks and potential problems that must be carefully explained to a customer before embarking on this implementation approach. This project type requires clear guidance from the customer and strong management from the implementation team. The frequency and intensity of communication associated with an Agile Project type is normally very high, resulting in a solution that reflects the customer’s business needs clearly. Additionally, because of the dynamic nature of the project approach, documentation is kept to a minimum throughout the project and is delivered with a barely-good-enough approach during requirement design. The Agile Project Type is typically used in implementation projects where one or more of the following circumstances exist: - Customer requirements are not fully defined or known up front. - Customer requires implementation to be flexible to accommodate changing business priorities. - Customer focus is on the delivery of solution and does not require complete documentation. - Customer-specific features are required. - Moderate-to-complex customizations are required. - Independent software vendor (ISV) solutions are included. - Simple-to-moderate infrastructure is involved. - Customer-specific integrations or interfaces to third-party systems are required. - Simple-to-complex data migration is involved. - Small-to-medium number of users will use the solution. |
|  13.06.2013, 13:15 | #2 |
| Участник | Цитата: Конечно все зависит от специфики проекта, его масштабов, и, в общем можно выразиться так: "Agile-это для маленьких и средних проектов, а Sure Step или "классика" для больших". Но не обязательно. Дело в том, что можно их успешно объединить! Например, начало и окончание проекта по классике водопада/каскада а серединка Agile (Scrum, Kanban...). Т.к. Вы совершенно верно заметили "a barely-good-enough approach during requirement design...Customer focus is on the delivery of solution and does not require complete documentation.", то классика позволит решить задачу документации а Agile отлично закроет часть разработки. Когда большой проект идет полностью по Agile, то тут основные проблемы: зафиксированные сроки и деньги; трассируемость требований (кот.всегда есть в классике, но как я уже знаю успешно решается и в Scrum). |
|  Похожие темы | ||||
| Тема | Ответов | |||
| Вакансия-Ведущий разработчик MS CRM (Москва) | 0 | |||
