Приведу код, который позволил сторнировать неправильные корректировки нереализованной курсовой. Для его работы требуется сделать public метод postExchAdj класса CustVendExchAdjustment_W. X++: CustTrans custTrans, custTrans2, custTransNew; CustSettlement custSettlement, custSettlement2; CustTransOpen custTransOpen, custTransOpen2; LedgerTrans ledgerTrans; ExchRate exchRate; CustVendExchAdjustment_W custVendExchAdjustment; CustVendTransSettlement custVendTransSettlement; CustVendSettle custVendSettle; CustVendExchAdj custVendExchAdj; CustVendExchAdjTrans custVendExchAdjTrans; LedgerVoucherGroup ledgerVoucherGroup; LedgerVoucher ledgerVoucher; LedgerVoucherObject ledgerVoucherObject; TransDate transDate = 31\03\2013; Voucher voucher; Set set = new Set(types::Container); SetIterator si; ; while select forupdate custTrans where custTrans.TransType != LedgerTransType::ExchAdjustment && custTrans.CurrencyCode != "RUR" notexists join custTransOpen2 where custTransOpen2.RefRecId == custTrans.RecId { if(custTrans.AmountMST != custTrans.SettleAmountMST - custTrans.ExchAdjustment) { if(custTrans.AmountMST == custTrans.SettleAmountMST - custTrans.CustExchAdjustmentRealized) { info(strfmt("Расходится на нереализованную курсовую;%1;%2;%3", custTrans.Voucher, custTrans.RecId, custTrans.TransDate)); while select custSettlement where custSettlement.TransRecId == custTrans.RecId && custSettlement.ExchAdjustment join custTrans2 where custTrans2.Voucher == custSettlement.OffsetTransVoucher && custTrans2.TransType == LedgerTransType::ExchAdjustment && custTrans2.CustExchAdjustmentUnrealized { set.add([custTrans.RecId, custTrans2.RecId]); } } else { info(strfmt(";%1;%2;%3", custTrans.Voucher, custTrans.RecId, custTrans.TransDate)); } } } ttsbegin; si = new SetIterator(set); while(si.more()) { custTrans = CustTrans::find(conpeek(si.value(), 1), true); custTrans2 = CustTrans::find(conpeek(si.value(), 2)); custVendTransSettlement = CustVendTransSettlement::construct(SysModule::Cust); custVendExchAdj = new CustExchAdj(); custVendExchAdjTrans = CustVendExchAdjTrans::construct(SysModule::Cust, custVendExchAdj); custVendExchAdjustment = CustVendExchAdjustment_W::newFromExchAdj(custVendExchAdj, custVendExchAdjTrans); custVendExchAdjustment.setCustVendTransSettlement(custVendTransSettlement); custVendExchAdjustment.parmTransactionDate(transDate); custVendExchAdjustment.setSettlementGroupPlaceHolder(1); ledgerVoucher = LedgerVoucher::newLedgerPost( DetailSummary::Summary, SysModule::Cust, "" ); ledgerVoucher.parmCompanyId(curext()); //voucher = NumberSeq::newGetNum(CustParameters::numRefCustExchAdjVoucher()).num(); voucher = custTrans2.Voucher; ledgerVoucherObject = LedgerVoucherObject::newVoucher( voucher, transDate, SysModule::Cust, LedgerTransType::ExchAdjustment, true ); ledgerVoucher.addVoucher(ledgerVoucherObject); custVendExchAdjustment.parmLedgerVoucher(ledgerVoucher); exchRate = ExchRates::findExchRateDate(custTrans.CurrencyCode, custVendExchAdjTrans.exchrateDate(custTrans)).ExchRate; custTrans.LastSettleVoucher = ledgerVoucher.lastVoucher(); custTrans.LastSettleCompany = ledgerVoucher.parmCompanyId(); custTrans.LastExchAdjVoucher = custTrans.LastSettleVoucher; custTrans.LastExchAdjRate = exchRate; custTrans.LastExchAdj = transDate; custTrans.LastSettleDate = custTrans.LastExchAdj; custTrans.update(); custVendExchAdjustment.postExchAdj( custTrans2.CustExchAdjustmentUnrealized, custTrans, true, false, "", datenull(), 0, NoneTableTrans::Transaction, custTrans.Dimension, custTrans.PostingProfile, false, "", 0, false, custTrans, custTrans, voucher ); custSettlement2 = custVendExchAdjustment.parmCustVendSettle().updateTransaction_W(custTrans, null); custVendTransSettlement.addSettlement(custSettlement2, 1, custTrans.TransType); ledgerVoucher.end(); custVendTransSettlement.post(); si.next(); } ttscommit; |
Вообще, в переоценке курсовых по закрытым проводкам нет ничего криминального. Так как допустим, сопоставили мы накладную с оплатой в текущем периоде. А переоценку курсовой на конец прошлого периода сделать забыли. А теперь хотим получить корректную отчетность на конец прошлого периода с учетом курсовых.
I could tell you, but then I would have to bill you. |
За это сообщение автора поблагодарили: byte (1). |
Сообщение от twilight
![]() Вообще, в переоценке курсовых по закрытым проводкам нет ничего криминального. Так как допустим, сопоставили мы накладную с оплатой в текущем периоде. А переоценку курсовой на конец прошлого периода сделать забыли. А теперь хотим получить корректную отчетность на конец прошлого периода с учетом курсовых.
Опции просмотра | |
