Старый 02.04.2013, 17:26   #1
Dreadlock is offline
Dreadlock
Аватар для Dreadlock
298 / 224 (8) ++++++
Или вот еще:
Код:
I know this is an old thread, but I believe I have a solution that works.
In the master page (AOT/Web/Web files/Static Files/defaultax), there is a control that makes a page auto-refresh, whenever you use the back button on the browser.
<Dynamics:AxRefreshOnBackButton ID="AxRefreshOnBackButton1" runat="server" />
You can either remove this (and loose the function on ie8), or you can add the following script just before the </body> tag
<script language="javascript" type="text/javascript">
    setTimeout(showAspForm, 500);
    function showAspForm() {
        if (!DynamicsCommon.IsNull($get('__axr_iframe')) && $get('aspnetForm').style.display == 'none') {
            $get('aspnetForm').style.display = '';
</script>
"push" the changed file to the filesystem, and it should work with all the browsers.
Only thing is, that a page still won't auto-refresh-on-back on any new browsers. (this only works in ie8)
Источник
Ax2009, Портал, разработка контролов в VS2008 Narayana DAX: Программирование 19 19.09.2013 13:08
Аксапта плохо видит портал при разработке Narayana DAX: Администрирование 2 11.12.2012 13:51
axinthefield: Choosing a Single Deployment or Multiple Deployments of AX2009 Blog bot DAX Blogs 0 15.06.2011 03:25
AX2009, Разные домены, клиент не видит АОС DSPIC DAX: Администрирование 4 15.09.2010 22:18
Shekhar: Dynamics AX2009 : Standalone Installation on Vista with Role centres and workflow. Blog bot DAX Blogs 0 30.03.2010 15:05
Часовой пояс GMT +3, время: 10:11.
