Старый 16.03.2013, 15:12   #1
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework (Old name - Data Migration Framework) is now available on Information source
Источник: http://blogs.msdn.com/b/axsa/archive...on-source.aspx
Link :- https://informationsource.dynamics.com//RFPServicesOnline/Rfpservicesonline.aspx?ToolDocName=Microsoft+Dynamics+AX+2012+Data+Import%2fExport+Framework%7cQJ4JEM76642V-8-1005
Some of the key features -
  • 70 Entities out of the box ( 40+ new entities added) - Master Data, Reference Data, Journals, etc
  • Support for creating custom entities using Custom entity creation wizard.
  • Support for AX 2012 RTM, R1 and R2.
  • Support for SQL 2008 and SQL 2012
  • Import Entity data from multiple sources - Flat File:-Delimited and Fixed Width, ODBC :– external data bases, Excel, etc.
  • Export Entity data from AX 2012 to - Other AX 2012 environments, Flat File
  • Copy Entity data across Legal entities
  • Entity types – Entity, composite entity and flat table.
  • Mapper control
  • Parallel execution support from staging to target using Task Bundling
  • Folder as input for running periodic import - with functionality to move files to different folders (In Process, Error and Completed)
  • Error handling - skipping error rows, etc.
  • Set based support for staging to target
  • Default value Support
  • Number sequence Support
  • External Key mapping Support
  • Source to Target in single step
  • Multiple AOS support
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Microsoft Dynamics CRM Team Blog: Create Sample Data for your Solution Blog bot Dynamics CRM: Blogs 0 01.12.2011 05:14
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 12:41.
