Старый 17.11.2012, 11:12   #1
amer-ax: Enterprise Portal is Not Working on Dynamics AX 2012 Hyper-V Image
Источник: http://www.amer-ax.com/2011/12/enter...hyper-v-image/
If you ever started working on the image downloaded from the Microsoft PartnerSource of Microsoft Dynamics AX 2012, you might face a trouble while trying to explore Role Centers or Enterprise Portals.
This error is due to the configuration setup in the AX2012 image that let’s DNS points to contoso.com domain. What has to be done is to redirect that domain to the current machine (which is the same virtual machine you’re using).
To do so you must add a loop back IP to your” Hosts” file. You can think of that files a Rolodex for your computer. Its where a computer looks first to translate the URL of a website into a numerical IP address that it can actually use. You can find the “Hosts” file in: “C:\Windows\System32\drivers\etc\Hosts”.
To fix the issue, open the Hosts file a notepad and add this line to the end of the file:
127.0.0.1       dynamicsax.contoso.com
In the beginning, you might encounter the below error… but it will be fixed with “refresh”:
dynamics-community.at: Neue Trainingsunterlage für Dynamics AX 2012: Enterprise Portal Development Blog bot DAX auf Deutsch 0 13.06.2012 00:13
Rahul Sharma: Claims-Based Flexible Authentication in Dynamics AX 2012 Blog bot DAX Blogs 0 02.05.2012 09:11
dynamics-ax: .Net Business Connector Not Recommend for AX 2012 Blog bot DAX Blogs 0 26.05.2011 23:11
daxdilip: Troubleshooting AX 2009 Enterprise Portal Error The type or namespace name "Portal" does not exist in namespace 'Microsoft.Dynamics' Blog bot DAX Blogs 0 12.08.2010 11:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 16:44.
