Заноза в заднице
Корректное изменение Organization ID
Ответ на этот вопрос тоже найден самостоятельно. Подробный разговор на эту тему здесь: http://social.microsoft.com/Forums/e...-22ffb8b7071c/
Но скрипт, которым воспользовался, такой: X++: DECLARE @OldOrganizationId uniqueidentifier, @NewOrganizationId uniqueidentifier -- The Old OrganizationId SET @OldOrganizationId = (SELECT TOP(1) OrganizationId FROM OrganizationBase) -- The New OrganizationId SET @NewOrganizationId = (SELECT NEWID()) --PRINT @OldOrganizationId --PRINT @NewOrganizationId -- Table with all Found Columns with the OrganizationId DECLARE @FoundOrganizationIds TABLE (Id bigint identity(1,1), TableName nvarchar(max), ColumnName nvarchar(max), ColumnValue nvarchar(max)) -- Table with all uniqueidentifier Columns in the Database DECLARE @FoundUniqueIdentifierColumns TABLE(Id bigint identity(1,1), TableName nvarchar(max), ColumnName nvarchar(max)) -- Search for all uniqueidentifier Columns in the Database INSERT INTO @FoundUniqueIdentifierColumns SELECT col.TABLE_NAME, col.COLUMN_NAME FROM INFORMATION_SCHEMA.TABLES tbl INNER JOIN INFORMATION_SCHEMA.COLUMNS col ON tbl.TABLE_NAME = col.TABLE_NAME WHERE tbl.TABLE_TYPE = 'BASE TABLE' AND col.DATA_TYPE IN ('uniqueidentifier') DECLARE @ColumnCount bigint SET @ColumnCount = (SELECT COUNT(*) FROM @FoundUniqueIdentifierColumns) -- PRINT CAST(@ColumnCount as nvarchar) DECLARE @Iterator bigint SET @Iterator = 1 -- Look through all found uniqueidentifier for the Old OrganizationId Columns and Save the TableName/ColumnName in @FoundOrganizationIds WHILE @Iterator <= @ColumnCount BEGIN DECLARE @execsql nvarchar(max) DECLARE @TableName nvarchar(max) DECLARE @ColumnName nvarchar(max) SET @TableName = (SELECT TableName FROM @FoundUniqueIdentifierColumns WHERE Id = @Iterator) SET @ColumnName = (SELECT ColumnName FROM @FoundUniqueIdentifierColumns WHERE Id = @Iterator) --PRINT(@TableName) --PRINT(@@ColumnName) SET @execsql = 'SELECT DISTINCT ' + CHAR(39) + @TableName + CHAR(39) + ',' SET @execsql = @execsql + CHAR(39) + @ColumnName + CHAR(39) + ',' SET @execsql = @execsql + @ColumnName SET @execsql = @execsql + ' FROM ' SET @execsql = @execsql + @TableName SET @execsql = @execsql + ' WHERE ' SET @execsql = @execsql + @ColumnName SET @execsql = @execsql + ' = ' + CHAR(39) + CAST(@OldOrganizationId as varchar(50)) + CHAR(39) INSERT INTO @FoundOrganizationIds (TableName, ColumnName, ColumnValue) -- PRINT (@execsql) EXEC (@execsql) SET @Iterator = @Iterator + 1 END -- SELECT * FROM @FoundOrganizationIds DECLARE @ColumnIterator bigint, @ColumnTotal bigint SET @ColumnIterator = 1 SET @ColumnTotal = (SELECT COUNT(id) FROM @FoundOrganizationIds) PRINT (@ColumnTotal) -- INSERT New Organization in the OrganizationTable with the new OrganizationId (Copy of the Old Organization but with the new Id) INSERT INTO [dbo].[OrganizationBase] ([OrganizationId] ,[Name] ,[UserGroupId] ,[PrivilegeUserGroupId] ,[FiscalPeriodType] ,[FiscalCalendarStart] ,[DateFormatCode] ,[TimeFormatCode] ,[CurrencySymbol] ,[WeekStartDayCode] ,[DateSeparator] ,[FullNameConventionCode] ,[NegativeFormatCode] ,[NumberFormat] ,[IsDisabled] ,[DisabledReason] ,[KbPrefix] ,[CurrentKbNumber] ,[CasePrefix] ,[CurrentCaseNumber] ,[ContractPrefix] ,[CurrentContractNumber] ,[QuotePrefix] ,[CurrentQuoteNumber] ,[OrderPrefix] ,[CurrentOrderNumber] ,[InvoicePrefix] ,[CurrentInvoiceNumber] ,[UniqueSpecifierLength] ,[CreatedOn] ,[ModifiedOn] ,[FiscalYearFormat] ,[FiscalPeriodFormat] ,[FiscalYearPeriodConnect] ,[LanguageCode] ,[SortId] ,[DateFormatString] ,[TimeFormatString] ,[PricingDecimalPrecision] ,[ShowWeekNumber] ,[NextTrackingNumber] ,[TagMaxAggressiveCycles] ,[TokenKey] ,[SystemUserId] ,[CreatedBy] ,[GrantAccessToNetworkService] ,[AllowOutlookScheduledSyncs] ,[AllowMarketingEmailExecution] ,[SqlAccessGroupId] ,[CurrencyFormatCode] ,[FiscalSettingsUpdated] ,[ReportingGroupId] ,[TokenExpiry] ,[ShareToPreviousOwnerOnAssign] ,[AcknowledgementTemplateId] ,[ModifiedBy] ,[IntegrationUserId] ,[TrackingTokenIdBase] ,[BusinessClosureCalendarId] ,[AllowAutoUnsubscribeAcknowledgement] ,[AllowAutoUnsubscribe] ,[Picture] ,[TrackingPrefix] ,[MinOutlookSyncInterval] ,[BulkOperationPrefix] ,[AllowAutoResponseCreation] ,[MaximumTrackingNumber] ,[CampaignPrefix] ,[SqlAccessGroupName] ,[CurrentCampaignNumber] ,[FiscalYearDisplayCode] ,[SiteMapXml] ,[IsRegistered] ,[ReportingGroupName] ,[CurrentBulkOperationNumber] ,[SchemaNamePrefix] ,[IgnoreInternalEmail] ,[TagPollingPeriod] ,[TrackingTokenIdDigits] ,[NumberGroupFormat] ,[LongDateFormatCode] ,[UTCConversionTimeZoneCode] ,[TimeZoneRuleVersionNumber] ,[CurrentImportSequenceNumber] ,[ParsedTablePrefix] ,[V3CalloutConfigHash] ,[IsFiscalPeriodMonthBased] ,[LocaleId] ,[ParsedTableColumnPrefix] ,[SupportUserId] ,[AMDesignator] ,[CurrencyDisplayOption] ,[MinAddressBookSyncInterval] ,[IsDuplicateDetectionEnabledForOnlineCreateUpdate] ,[FeatureSet] ,[BlockedAttachments] ,[IsDuplicateDetectionEnabledForOfflineSync] ,[AllowOfflineScheduledSyncs] ,[AllowUnresolvedPartiesOnEmailSend] ,[TimeSeparator] ,[CurrentParsedTableNumber] ,[MinOfflineSyncInterval] ,[AllowWebExcelExport] ,[ReferenceSiteMapXml] ,[IsDuplicateDetectionEnabledForImport] ,[CalendarType] ,[SQMEnabled] ,[NegativeCurrencyFormatCode] ,[AllowAddressBookSyncs] ,[ISVIntegrationCode] ,[DecimalSymbol] ,[MaxUploadFileSize] ,[IsAppMode] ,[EnablePricingOnCreate] ,[IsSOPIntegrationEnabled] ,[PMDesignator] ,[CurrencyDecimalPrecision] ,[MaxAppointmentDurationDays] ,[EmailSendPollingPeriod] ,[RenderSecureIFrameForEmail] ,[NumberSeparator] ,[PrivReportingGroupId] ,[BaseCurrencyId] ,[MaxRecordsForExportToExcel] ,[PrivReportingGroupName] ,[YearStartWeekCode] ,[IsPresenceEnabled] ,[IsDuplicateDetectionEnabled] ,[RecurrenceExpansionJobBatchInterval] ,[DefaultRecurrenceEndRangeType] ,[HashMinAddressCount] ,[RequireApprovalForUserEmail] ,[RecurrenceDefaultNumberOfOccurrences] ,[ModifiedOnBehalfBy] ,[RequireApprovalForQueueEmail] ,[AllowEntityOnlyAudit] ,[IsAuditEnabled] ,[RecurrenceExpansionSynchCreateMax] ,[GoalRollupExpiryTime] ,[BaseCurrencyPrecision] ,[FiscalPeriodFormatPeriod] ,[AllowClientMessageBarAd] ,[InitialVersion] ,[HashFilterKeywords] ,[NextCustomObjectTypeCode] ,[ExpireSubscriptionsInDays] ,[OrgDbOrgSettings] ,[PastExpansionWindow] ,[EnableSmartMatching] ,[MaxRecordsForLookupFilters] ,[BaseCurrencySymbol] ,[ReportScriptErrors] ,[RecurrenceExpansionJobBatchSize] ,[FutureExpansionWindow] ,[GetStartedPaneContentEnabled] ,[SampleDataImportId] ,[BaseISOCurrencyCode] ,[GoalRollupFrequency] ,[CreatedOnBehalfBy] ,[HashDeltaSubjectCount] ,[HashMaxCount] ,[FiscalYearFormatYear] ,[FiscalYearFormatPrefix] ,[PinpointLanguageCode] ,[FiscalYearFormatSuffix] ,[IsUserAccessAuditEnabled] ,[UserAccessAuditingInterval]) SELECT @NewOrganizationId, [Name] ,[UserGroupId] ,[PrivilegeUserGroupId] ,[FiscalPeriodType] ,[FiscalCalendarStart] ,[DateFormatCode] ,[TimeFormatCode] ,[CurrencySymbol] ,[WeekStartDayCode] ,[DateSeparator] ,[FullNameConventionCode] ,[NegativeFormatCode] ,[NumberFormat] ,[IsDisabled] ,[DisabledReason] ,[KbPrefix] ,[CurrentKbNumber] ,[CasePrefix] ,[CurrentCaseNumber] ,[ContractPrefix] ,[CurrentContractNumber] ,[QuotePrefix] ,[CurrentQuoteNumber] ,[OrderPrefix] ,[CurrentOrderNumber] ,[InvoicePrefix] ,[CurrentInvoiceNumber] ,[UniqueSpecifierLength] ,[CreatedOn] ,[ModifiedOn] ,[FiscalYearFormat] ,[FiscalPeriodFormat] ,[FiscalYearPeriodConnect] ,[LanguageCode] ,[SortId] ,[DateFormatString] ,[TimeFormatString] ,[PricingDecimalPrecision] ,[ShowWeekNumber] ,[NextTrackingNumber] ,[TagMaxAggressiveCycles] ,[TokenKey] ,[SystemUserId] ,[CreatedBy] ,[GrantAccessToNetworkService] ,[AllowOutlookScheduledSyncs] ,[AllowMarketingEmailExecution] ,[SqlAccessGroupId] ,[CurrencyFormatCode] ,[FiscalSettingsUpdated] ,[ReportingGroupId] ,[TokenExpiry] ,[ShareToPreviousOwnerOnAssign] ,[AcknowledgementTemplateId] ,[ModifiedBy] ,[IntegrationUserId] ,[TrackingTokenIdBase] ,[BusinessClosureCalendarId] ,[AllowAutoUnsubscribeAcknowledgement] ,[AllowAutoUnsubscribe] ,[Picture] ,[TrackingPrefix] ,[MinOutlookSyncInterval] ,[BulkOperationPrefix] ,[AllowAutoResponseCreation] ,[MaximumTrackingNumber] ,[CampaignPrefix] ,[SqlAccessGroupName] ,[CurrentCampaignNumber] ,[FiscalYearDisplayCode] ,[SiteMapXml] ,[IsRegistered] ,[ReportingGroupName] ,[CurrentBulkOperationNumber] ,[SchemaNamePrefix] ,[IgnoreInternalEmail] ,[TagPollingPeriod] ,[TrackingTokenIdDigits] ,[NumberGroupFormat] ,[LongDateFormatCode] ,[UTCConversionTimeZoneCode] ,[TimeZoneRuleVersionNumber] ,[CurrentImportSequenceNumber] ,[ParsedTablePrefix] ,[V3CalloutConfigHash] ,[IsFiscalPeriodMonthBased] ,[LocaleId] ,[ParsedTableColumnPrefix] ,[SupportUserId] ,[AMDesignator] ,[CurrencyDisplayOption] ,[MinAddressBookSyncInterval] ,[IsDuplicateDetectionEnabledForOnlineCreateUpdate] ,[FeatureSet] ,[BlockedAttachments] ,[IsDuplicateDetectionEnabledForOfflineSync] ,[AllowOfflineScheduledSyncs] ,[AllowUnresolvedPartiesOnEmailSend] ,[TimeSeparator] ,[CurrentParsedTableNumber] ,[MinOfflineSyncInterval] ,[AllowWebExcelExport] ,[ReferenceSiteMapXml] ,[IsDuplicateDetectionEnabledForImport] ,[CalendarType] ,[SQMEnabled] ,[NegativeCurrencyFormatCode] ,[AllowAddressBookSyncs] ,[ISVIntegrationCode] ,[DecimalSymbol] ,[MaxUploadFileSize] ,[IsAppMode] ,[EnablePricingOnCreate] ,[IsSOPIntegrationEnabled] ,[PMDesignator] ,[CurrencyDecimalPrecision] ,[MaxAppointmentDurationDays] ,[EmailSendPollingPeriod] ,[RenderSecureIFrameForEmail] ,[NumberSeparator] ,[PrivReportingGroupId] ,[BaseCurrencyId] ,[MaxRecordsForExportToExcel] ,[PrivReportingGroupName] ,[YearStartWeekCode] ,[IsPresenceEnabled] ,[IsDuplicateDetectionEnabled] ,[RecurrenceExpansionJobBatchInterval] ,[DefaultRecurrenceEndRangeType] ,[HashMinAddressCount] ,[RequireApprovalForUserEmail] ,[RecurrenceDefaultNumberOfOccurrences] ,[ModifiedOnBehalfBy] ,[RequireApprovalForQueueEmail] ,[AllowEntityOnlyAudit] ,[IsAuditEnabled] ,[RecurrenceExpansionSynchCreateMax] ,[GoalRollupExpiryTime] ,[BaseCurrencyPrecision] ,[FiscalPeriodFormatPeriod] ,[AllowClientMessageBarAd] ,[InitialVersion] ,[HashFilterKeywords] ,[NextCustomObjectTypeCode] ,[ExpireSubscriptionsInDays] ,[OrgDbOrgSettings] ,[PastExpansionWindow] ,[EnableSmartMatching] ,[MaxRecordsForLookupFilters] ,[BaseCurrencySymbol] ,[ReportScriptErrors] ,[RecurrenceExpansionJobBatchSize] ,[FutureExpansionWindow] ,[GetStartedPaneContentEnabled] ,[SampleDataImportId] ,[BaseISOCurrencyCode] ,[GoalRollupFrequency] ,[CreatedOnBehalfBy] ,[HashDeltaSubjectCount] ,[HashMaxCount] ,[FiscalYearFormatYear] ,[FiscalYearFormatPrefix] ,[PinpointLanguageCode] ,[FiscalYearFormatSuffix] ,[IsUserAccessAuditEnabled] ,[UserAccessAuditingInterval] FROM [dbo].[OrganizationBase] WHERE OrganizationId = @OldOrganizationId -- Loop through the Found Columns and Update them with the new OrganizationId WHILE @ColumnIterator <= @ColumnTotal BEGIN DECLARE @CurrentTable nvarchar(max) DECLARE @CurrentColumn nvarchar(max) SET @CurrentTable = (SELECT TableName FROM @FoundOrganizationIds WHERE Id = @ColumnIterator) SET @CurrentColumn = (SELECT ColumnName FROM @FoundOrganizationIds WHERE Id = @ColumnIterator) --PRINT (@CurrentTable) --PRINT (@CurrentColumn) -- Skip the OrganizationBase table now, since we have allready added the new OrganizationId IF @CurrentTable <> 'OrganizationBase' BEGIN DECLARE @UpdateScript nvarchar(max) SET @UpdateScript = ' UPDATE ' + @CurrentTable + ' SET ' + @CurrentColumn + ' = ' + CHAR(39) + CAST(@NewOrganizationId as varchar(50)) + CHAR(39) + ' WHERE ' + @CurrentColumn + ' = ' + CHAR(39) + CAST(@OldOrganizationId as varchar(50))+ CHAR(39) -- PRINT (@UpdateScript) EXEC (@UpdateScript) END SET @ColumnIterator = @ColumnIterator + 1 END -- Delete the Old Organization from the OrganizationBase DELETE FROM OrganizationBase WHERE OrganizationId = @OldOrganizationId
Лень мудрого человека - это необходимое средство нейтрализации кипучей активности руководящих им дураков! |
За это сообщение автора поблагодарили: Артем Enot Грунин (3). |
Опции просмотра | |
