Хелп, кто-нибудь сталкивался с проблемой, при которой стандартные отчеты, которые есть по умолчанию работают, а если создаешь свой любой отчет даже через СРМ, то пишет
![]() Если нажимаешь "повтор попытки", пишет "недопустимый аргумент". Еще пару раз на повтор "404 - File or directory not found." В логе приложения: Event code: 3005 Event message: An unhandled exception has occurred. Event time: 8/31/2012 11:23:07 AM Event time (UTC): 8/31/2012 7:23:07 AM Event ID: aaf70ff1dd904e6b950c87885c201da6 Event sequence: 34172 Event occurrence: 26 Event detail code: 0 Application information: Application domain: /LM/W3SVC/1/ROOT-1-129908158689239396 Trust level: Full Application Virtual Path: / Application Path: C:\Program Files\Microsoft Dynamics CRM\CRMWeb\ Machine name: WZ-CRM01 Process information: Process ID: 3180 Process name: w3wp.exe Account name: NT AUTHORITY\NETWORK SERVICE Exception information: Exception type: CrmArgumentNullException Exception message: name at Microsoft.Crm.ReportObjectModel.ReportServerOrganizationContext.GetItemPath(String name, Boolean isSharedReport) at Microsoft.Crm.Web.Reporting.RemoteSrsReportViewer.LoadReportAndSetParameters() at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) Value cannot be null. Parameter name: name Request information: Request URL: http://wz-crm01/test/CRMReports/rsvi...ortviewer.aspx Request path: /test/CRMReports/rsviewer/reportviewer.aspx User host address: 172.16.32.177 User: domen\user Is authenticated: True Authentication Type: NTLM Thread account name: NT AUTHORITY\NETWORK SERVICE Thread information: Thread ID: 40 Thread account name: NT AUTHORITY\NETWORK SERVICE Is impersonating: False Stack trace: at Microsoft.Crm.ReportObjectModel.ReportServerOrganizationContext.GetItemPath(String name, Boolean isSharedReport) at Microsoft.Crm.Web.Reporting.RemoteSrsReportViewer.LoadReportAndSetParameters() at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) Custom event details: Такое ощущение, что проблема в правах, но не могу понять где, репорты и стандартные же отчеты работают. |
С правами, я думаю, все нормально.
У Вас ошибка в аргументе отчета: Exception type: CrmArgumentNullException Exception message: name Value cannot be null. Parameter name: name А в чем был создан отчет? Вы в BIDS создаете отчеты? А самый простой отчет пробовали создавать в мастере отчетов CRM?
Материалы для внедренцев Microsoft Dynamics CRM теперь на сайте Infoleat.com и в моем блоге CRM для бизнеса |
Сообщение от Fighter
У Вас ошибка в аргументе отчета: Exception type: CrmArgumentNullException Exception message: name Value cannot be null. Parameter name: name А в чем был создан отчет? Вы в BIDS создаете отчеты? А самый простой отчет пробовали создавать в мастере отчетов CRM? http://blogs.salentica.com/direland/...rts-dont-work/ нашла статью, SPN создали, ситуация не изменилась... Данная ошибка появляется только если 3 раза нажать на кнопку повторить Потом выскакивает "HTTP Error 404.15 - Not Found The request filtering module is configured to deny a request where the query string is too long." Если повторить 3 раза не нажимать, то обычная ошибка в логе: Log Name: Application Source: MSCRMReporting Date: 8/31/2012 2:18:35 PM Event ID: 19970 Task Category: None Level: Error Keywords: Classic User: N/A Computer: WZ-CRM01 Description: Report render failure. Error: An error has occurred during report processing. (rsProcessingAborted) Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="MSCRMReporting" /> <EventID Qualifiers="49152">19970</EventID> <Level>2</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2012-08-31T10:18:35.000000000Z" /> <EventRecordID>195193</EventRecordID> <Channel>Application</Channel> <Computer>WZ-CRM01</Computer> <Security /> </System> <EventData> <Data>An error has occurred during report processing. (rsProcessingAborted)</Data> <Data>w3wp</Data> <Data>C:\Program Files\Microsoft Dynamics CRM\CRMWeb\</Data> </EventData> </Event> |
Чайный пьяница
Включайте трейс, перезапускайте иис, воспроизводите ошибку, читайте логи.
Сообщение от Ponka
![]() Если нажимаешь "повтор попытки", пишет "недопустимый аргумент". Еще пару раз на повтор "404 - File or directory not found." В логе приложения: Event code: 3005 Event message: An unhandled exception has occurred. Event time: 8/31/2012 11:23:07 AM Event time (UTC): 8/31/2012 7:23:07 AM Event ID: aaf70ff1dd904e6b950c87885c201da6 Event sequence: 34172 Event occurrence: 26 Event detail code: 0 Application information: Application domain: /LM/W3SVC/1/ROOT-1-129908158689239396 Trust level: Full Application Virtual Path: / Application Path: C:\Program Files\Microsoft Dynamics CRM\CRMWeb\ Machine name: WZ-CRM01 Process information: Process ID: 3180 Process name: w3wp.exe Account name: NT AUTHORITY\NETWORK SERVICE Exception information: Exception type: CrmArgumentNullException Exception message: name at Microsoft.Crm.ReportObjectModel.ReportServerOrganizationContext.GetItemPath(String name, Boolean isSharedReport) at Microsoft.Crm.Web.Reporting.RemoteSrsReportViewer.LoadReportAndSetParameters() at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) Value cannot be null. Parameter name: name Request information: Request URL: http://wz-crm01/test/CRMReports/rsvi...ortviewer.aspx Request path: /test/CRMReports/rsviewer/reportviewer.aspx User host address: 172.16.32.177 User: domen\user Is authenticated: True Authentication Type: NTLM Thread account name: NT AUTHORITY\NETWORK SERVICE Thread information: Thread ID: 40 Thread account name: NT AUTHORITY\NETWORK SERVICE Is impersonating: False Stack trace: at Microsoft.Crm.ReportObjectModel.ReportServerOrganizationContext.GetItemPath(String name, Boolean isSharedReport) at Microsoft.Crm.Web.Reporting.RemoteSrsReportViewer.LoadReportAndSetParameters() at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) Custom event details: Такое ощущение, что проблема в правах, но не могу понять где, репорты и стандартные же отчеты работают. 1. Откройте командную строку с правами администратора 2. Выполните последовательно следующие команды, подставив соответствующие значения: setspn -a http/<CrmApplicationServerName> <CrmAppPoolServiceUserAccount> (например setspn -a http/crm mycrm\CrmInstaller) setspn -a http/<CrmApplicationServer FQDN> <CrmAppPoolServiceUserAccount> (например setspn -a http/crm.mycrm.local mycrm\CrmInstaller) 3. Откройте IIS Manager 4. Найдите сайт Microsoft Dynamics CRM 5. В разделе Management выберите Configuration Editor 6. В раздел From выберите ApplicationHost.config <location path=… и в разделе Section:" location, select system.webServer > security > authentication > windowsAuthentication. 7. Для параметра useAppPoolCredentials установите значение true. 8. Нажмите apply Статья базы знаний более детально описывающая данное решение http://support.microsoft.com/kb/2590774?wa=wsignin1.0 |
Друзья, такая же проблема.
Есть отчет. Отлично работает, если в датасет поместить обычный селект. Но после того как я селект вынес в отдельную хранимую процедуру базы и в датасете сделал ссылку на эту процедуру, то при запуске отчета в CRM выдается аналогичная ошибка. Есть еще мысли? |
