Старый 27.04.2012, 22:11   #1
ax-erp: How to format your number the CLR style
Источник: http://microsoft-dynamics-ax-erp.blo...clr-style.html
Converting (real) numbers to a string representation is a common requirement. There are different roads that lead to Rome, I'll show you some alternatives, which all have one thing in common: They all use
Format
You can use
num2str
to convert your real numbers to a string, or you can use Format.
Example, controlling the number of decimals showed: (decimal point acts as decimal separator)
[COLOR=white !important]?
1
2
3
4
5
6
7
static void FormatExamples(Args _args)
real mynumber=123.4;
String30 mynumberstr = System.String::Format("{0,0:#.00}", mynumber);
info(strfmt("Your number is %1", mynumberstr));
[/COLOR]
You can use the Format command to add leading zeros also.
Example:
1
2
3
4
5
6
7
real mynumber=123;
String30 mynumberstr = System.String::Format("{0,0:00000}", mynumber);
[/COLOR]
Notice that you can also use rounding like this as well. Besides this basic function, we can actually do some conversions.
You can use Format to convert to
hexadecimal
for example.
Example:
1
2
3
4
5
6
7
int mynumber=255;
String30 mynumberstr = System.String::Format("{0,0:X}", mynumber);
info(strfmt("Your number in Hex: %1", mynumberstr));
[/COLOR]
axinthefield: How Preallocated Number Sequences are Cached in AX Blog bot DAX Blogs 0 03.05.2011 06:15
Часовой пояс GMT +3, время: 02:47.
