Старый 21.03.2012, 02:43   #6
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Ваша проблема связанна именно с транзакционностью плагинов CRM 2011. В SDK по этому поводу даже есть несколько строк:
Access to the Organization Service
To access the Microsoft Dynamics CRM organization service, it is required that plug-in code create an instance of the service through the ServiceProvider.GetService method.
C# Copy Code // Obtain the organization service reference. IOrganizationServiceFactory serviceFactory = (IOrganizationServiceFactory)serviceProvider.GetService(typeof(IOrganizationServiceFactory)); IOrganizationService service = serviceFactory.CreateOrganizationService(context.UserId);
The platform provides the correct Web service URLs and network credentials for you when you use this method. Instantiating your own Web service proxy is not supported as it will create deadlock and authentication issues.
За это сообщение автора поблагодарили: Konstantin Katsovich (1).
Microsoft Dynamics CRM Team Blog: Introduction to the Microsoft Dynamics CRM November 2011 service update Blog bot Dynamics CRM: Blogs 0 02.11.2011 04:17
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 4 Blog bot Dynamics CRM: Blogs 0 24.09.2011 01:16
Microsoft Dynamics CRM Team Blog: Update Rollup 4 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 22.09.2011 20:11
crminthefield: Microsoft Dynamics CRM 4.0 and 2011 Update Rollup Release Dates, Build Numbers, and Collateral Blog bot Dynamics CRM: Blogs 0 24.08.2011 02:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Online Test Drive Guide Blog bot Dynamics CRM: Blogs 0 05.08.2011 20:13
Часовой пояс GMT +3, время: 07:23.
